Homelite 245
Alex Kerr
09-22-2001 10:22:42
I've just been offered a Homelite 245 that's been sitting in a garage for a number of years since it's original purchaser died.
It appears to be in excellent condition, but will not even attempt to fire and has no manual. Putting a small quantity of 40:1 mix in the spark plug hole or directly into the carb gets it to fire up for a few seconds so it looks like a fuel problem.
Does anyone have a manual that they would be able to scan and forward to me and/or any words of wisdom regarding carb setting (in particular the hi low screws)?
All assistance would be most appreciated.
Thanks in advance
Alex
YVON
12-05-2005 01:06:48
 Re: Homelite 245 in reply to Alex Kerr, 09-22-2001 10:22:42
I WOULD LIKE TO KNOW WHY MY Homelite 245 SPITS OUT OF THE MUFFLER.CAN IT BECUSE OF OLD GAZ? TOO MUCH OIL IN GAZ?(IT HAS A NEW SPARK PLUG)
John in MA
09-22-2001 16:51:01
Any old chainsaw that's been sitting for that long will need a carb kit. The diaphrams become stiff with age. That's happened to ALL the chainsaws I from people who didn't use them. Also, don't use carb cleaner until the whole thing is dissasembled. That stuff does a great job of disolving the rubber seals in these carbs. Replace the fuel lines while you're at it.
yvon
12-01-2005 23:11:33
 Re: Re: Homelite 245 in reply to John in MA, 09-22-2001 16:51:01
#1 Replace the fuel lines and the fuel filter to!!!
#2 the diaphrams are not finish i have a 245 too i looked at it in all the ways possible im looking for the manual too
Rob Bailey
06-01-2002 22:10:29
I need to find someone in Perth Western Australia, who sells Homelite chainsaws. I have an old 200 and I've lost the w/shop manual.
Regards Rob Bailey
Ray
09-22-2001 13:36:56
Alex
Clean that carb real well with spray carb cleaner inside and out, leave the hi/lo screws where you find them and replace the fuel line with fresh tubing. Make sure the tank is clean and the filter should also be replaced. start with a 25-1 mix and it should run for you. The crankshaft seals may be dry depending on how long it sat.Good Luck
