Tool Talk Discussion Forum
trailer brakes
cb
05-21-2008 09:40:24
i have a small 6X10 flatbed trailer, shop made, it apparently has an axle and wheels from a older camper. it has wires for electric brakes.i remeoved the hubs to look. probably never hooked the brakes up. pads like new. how do i check to see if the brakes work. i hooked the wires to a truck battery. nothing happened. what do i need to do check to see if they work. anybody have diagram of a standard electric brake setup. thanks for any help. have a good day
cb
05-21-2008 13:53:37
 Re: trailer brakes in reply to cb, 05-21-2008 09:40:24
hello again. as i said i really dont need the brakes, but knowing they r there drives me to find out if they work. i dont intend to spend any money, just my time. thanks to all have a good nite
Dick L
05-21-2008 13:43:22
You may not want them hooked up. I have brakes on a light trailer and even with setting the controlled to its lightes setting when the trailer is empty the tires slide and squeel as soon as I press on the brake. I put a toggle switch on the trailer and only turn them on when I have a heavy load. I know you can get lighter magnets that might correct the problem but with what was used to make the trailer is what I have. Brakes are not required here for my light trailer.
cb
05-21-2008 12:04:48
thanks again for ur replies. i did check, it has continuity. i wiil give the other suggestions a try tomorrow. if i appear to be smart as a fence post. it may be true. it is not necessary for the brakes to work, but since they r there i would like to use them. have a good evening.
soundguy
05-21-2008 11:38:04
Spin the wheel and then energize the magnets... they don't do a whole lot just setting there...
soundguy
Mike M
05-21-2008 10:10:31
One wire to hot and the other to ground should engerize the magnets ,then the magnet contacts the drum and pulls on the brake arm as it moves.
cb
05-21-2008 10:55:28
 Re: trailer brakes in reply to Mike M, 05-21-2008 10:10:31
thanks mr. mike for the reply. i must not have had a good connection. i hooked the wires to my truck battery, nothing happened i will try again. how do i know if the magnets or there or if the thing is complete and not missing some part. the 2 wires goes to the piece that i suppose is the magnets. i will use a meter to check the continuity of the wiring. have a good day.
Mike M
05-21-2008 11:10:51
 Re: trailer brakes in reply to cb, 05-21-2008 10:55:28
The magnets may not be any good either ? I had a few go bad on one trailer with house trailer axles. Check for continuity if none then they must have a broken wire.
old
05-21-2008 11:02:01
If you still have the hub off if you hook up that battery it should hum some plus if you take a screw driver etc. t should hold what ever you put on it when its hooked up
