Help in installing an Automatic Drain on air compressor
Bill
09-21-2001 07:17:43
I have a Cambell Hausfeld Compressor Model Number VT5587, it's an up right compressor. I also just bought an auto compressor drainer kit for it from Harbor Freight. The only problem is that so far I can't figure out how to hook it up.. It says to hook inline with Vented Pressue switch, pilot valve or receiver pressure unloader. The other option is discharge unloader or check valve. Can't seem to find any indication in my compressor manual for any of these. Please help.
Thanks..
Bill
Fred, SC
06-12-2002 13:30:37
 Re: Help in installing an Automatic Drain on air compressor in reply to Bill, 09-21-2001 07:17:43
Someone else had the same problem. See>Link
good>Link luck!
Franz
09-22-2001 18:43:44
What they are referring to is the head unloader discharge from the pressure switch, if your switch has one, that would be where the air comes out of when the compressor shuts off.
Connect a line from that to the connection on the "automatic vent" and every time the compressor shuts down, the exhausted air will open the drain valve and empty the tank of moisture.
After you go thru all that hookup, the thing will work for a week or 2 since it's from Harbour Freight.
Ray,IN
09-21-2001 19:47:41
You might call their customer service dept. and request clarification of instructions.
Alvin NE WI
09-22-2001 16:55:54
 Re: Re: Help in installing an Automatic Drain on air compressor in reply to Ray,IN, 09-21-2001 19:47:41
If you got it from Harbor freight, and call the manufacture and get customer service , they will probably be speaking Chinese
