Tool Talk Discussion Forum
Plastic buckets stuck together
Hersel
05-21-2008 03:17:14
Have a couple dozen plastic buckets in two stacks that I can"t get apart. Any BTDT or suggestions?
Thanks
Charlien
05-23-2008 17:56:47
 Re: Plastic buckets stuck together in reply to Hersel, 05-21-2008 03:17:14
Take a rubber mallet and tap on the edge of the bottom one.Don't hit it hard ,just tap.Old hod carriers trick from an old hod carrier. Good luck.
Gary in Geneva
05-23-2008 06:06:53
Fill the space between them with water. It helps to lift the top bucket, and makes the bottom one heaver so you can lift the top one. Works good on stuck trash cans.
GeneMO
05-21-2008 19:15:51
Between each stuck bucket, drill a small hole in the side, under the top bucket. Gradually trickle about 100 grains of black powder down. Then using cannon fuse, light the powder. you can do this individually or using electric blasting caps, set the whole stack off at once.
I've never actually done this, but it ought to be fun.
Gene
Billpa
05-21-2008 12:42:53
put the bucket and handle in the outside bucket !
soundguy
05-21-2008 11:46:53
Hendrik and BW got the right idea.. and hang them upside down during this amneuver.. let gravity be your friend.
soundguy
TxFarmallFan
05-21-2008 08:09:18
Easy fix: just throw em away.
old
05-21-2008 07:56:53
BTDT my self. What I did was take a hammer and tap on each of them till they popped loose. Tap them down/off
richard lee
05-21-2008 05:36:30
Pay youre kids .25 for each pail, should keep them out of youre hair for awhile.
IaGary
05-21-2008 04:15:50
Hang them up by the handle and as they heat and cool they will fall apart.
Hendrik
05-21-2008 04:05:58
Blow compressed air between the buckets. That's how cup shaped, stacked products are separated in manufacturing processes. Works like a charm.
jeffcat
05-21-2008 21:41:39
 Re: Plastic buckets stuck together in reply to Hendrik, 05-21-2008 04:05:58
I agree with this one and would also tell you this. Take a trash can and fill it with hot water. Dip the bottom of the stack in and as the buckets heat they will come apart. I have a hot and cold faucet on my house outside so I would just use the hose with hot water. Have fun.
Crem
05-21-2008 05:42:26
Hendrick is right. Blowing compressed air between the buckets with a nozzle works slick
B W in MO
05-21-2008 04:01:03
Run hot water over the outside one it should come off. B W
charlesinnc
05-21-2008 07:17:18
 Re: Plastic buckets stuck together in reply to B W in MO, 05-21-2008 04:01:03
also to stop this in the future, drop a tennis ball inside each bucket.
Joe S
05-21-2008 09:09:37
 Re: Plastic buckets stuck together in reply to charlesinnc, 05-21-2008 07:17:18
I saw a guy use an empty quart oil bottle (lid on tight) between each bucket. cheaper than a tennis ball.
