Tool Talk Discussion Forum
5-Way Light Switch??
Glenn F.
05-20-2008 10:03:19
In wiring my garage I would like to have a bank of lights controlled by four switches (in different locations). I assume this would be a 5-way switch system. Can this be done? What type of switches will I need?
Thank you,
Glenn F.
Glenn F.
05-21-2008 04:36:30
 Re: 5-Way Light Switch?? in reply to Glenn F., 05-20-2008 10:03:19
Thank you for your responses. I'll be starting the project in about three weeks.
Glenn F.
Dusty MI
05-20-2008 10:21:59
Yes it can be done. 2-3way and 3-4way. The 3 way at the ends just like it were to be for 2 switches, then the 4 ways inserted between in the travelers.
huntingreen59
05-20-2008 10:15:04
Not hard to do at all. Just takes expensive 4 way switches and the wire between them. 3 way swiches on each end and 4 ways in the middle. What material are you using for wire?
Bill in IL
05-20-2008 10:09:48
You need two 3 way switches at either end of the ciruit and then 4 way switches in between. You can put in as many as you need to add more avaliable switches. Maybe someone has a diagram or you could google 3 and 4 way switches. Its really not very complicated once you see it drawn out.
