Tool Talk Discussion Forum
Wood Stove hot water
tractormarkb
05-19-2008 08:50:54
I am putting in a coil to heat water in my wood stove. My question is if lp Water Heaters have thermocouples in them so they dont reheat the already hot water coming in from the wood stove?
36 coupe
05-20-2008 05:32:46
 Re: Wood Stove hot water in reply to tractormarkb, 05-19-2008 08:50:54
Thats not the problem.Coils plug up with lime deposits.The old water heating systems in kitchen stoves exploded when waterflow shut down because of lime deposits.Do it right or not at all.
jdemaris
05-20-2008 06:11:19
 Re: Wood Stove hot water in reply to 36 coupe, 05-20-2008 05:32:46
All it needs is a thermal/pressure relief valve installed and it cannot "blow up." Just as all tank-type hot water heaters have.
In regard to mineral deposits - I have very hard water, and . . . heat my large house entirely with wood - and all domestic hot water with a thermosipon system (wood in winter-spring-fall and solar in summer). I pull the coils out once every three years and flush out - it takes me an hour. When coils DO start to plug - they give lots of warning with the pinging sounds they make.
I'm not sure that you are calling "doing it right." I'll add though, that a circultor is usually needed in a heating sytem that only produces heat off-and-on - e.g. oil, propane, gas, etc. It needs to heat water fast while firing and thusly needs a circulator. To the converse - a wood fire heats continuously - and if only heating domestic water, and thermosiphon alone usually makes more hot water than a household can use. Mid winter - I often have to bleed hot water off my 80 gallon storage tank - otherwise the thermal-relief valves keep tripping. A circulator and aquastat would be extra unneeded baggage and result in making way too much hot water unless you could find a use for it.
I did know a guy that used a large wood furnace, coils and a circulator - and made all his domestic hot water, also his home heat with hot-water baseboard heat, and . . . still had too much hot water. He then put coils outside under his driveway and heated it. It was kind of a funny thing to see - with ice melting and steam coming off it mid-winter.
36 coupe
05-25-2008 03:22:52
 Re: Wood Stove hot water in reply to jdemaris, 05-20-2008 06:11:19
Have seen systems with out a valve or valve connected wrong.Valves with out a exhaust pipe.Stove pipes without dampers are common.
tatanka
05-19-2008 11:09:49
Whats your plan for the hot water, Is it for pre heating the water for your house. Do you have a storage tank before your How Water Heater. You will need a small circulating pump to keep the water moving. Whats your plan for cycleing the woodstove when the water gets to temp. Let me know and Ill give you some pointers. I have experience in Boilers & HVAC
jdemaris
05-19-2008 11:55:06
 Re: Wood Stove hot water in reply to tatanka, 05-19-2008 11:09:49
A cirulator is not necessary. Thermosiphon coils work fine when hooked up properly. I've got one here I've been using for 20 years - thermosiphon hooked to an 80 gallon storage tank - that sends water onto an LP tank-type heater.
LP heater is protected from overly hot water with a tempering valve. Thermosiphon coils also have a self-bleed valve on top, and a one-way check-valve on the bottom.
Nice thing about thermo-siphon is - there's nothing electric to go wrong or wear out. third party image
third party image
third party image
third party image
Stan in Oly, WA
05-19-2008 11:01:50
Hi,
The information you've gotten is right, but I don't know if it exactly answers the question you asked. To answer your question, no, the thermocouple is not what keeps the water heater from wasting fuel by putting more heat into water that is already hot. The thermostat does that. What the thermocouple does is to shut off the gas flow if the pilot light goes out.
All the best, Stan
jdemaris
05-19-2008 11:23:29
 Re: Wood Stove hot water in reply to Stan in Oly, WA, 05-19-2008 11:01:50
Yes, that certainly applies if his heater has a pilot light. But . . . thermocouples are used for all sorts of things - even as crude thermostats in some applicances, and sometimes hooked in series as "thermopiles." The word though - when used in reference to propane or gas heaters - usually (but not always) refers to the "thermocouple" that measuses temperature differential and converts to millivolts - to turn on the gas valve.
In this case, he hasn't mentioned what type of heater his has, e.g. tank, tankless, with pilot light, elect. ignition, etc.
Some LP tank heaters have a "thermal fuse" in the gas valve that will blow if incoming water is too hot and never again reset. That can be a problem with wood-heated water unless the water temp from the wood fire is controlled.
Most standard tankless LP heaters use a flow valve to turn on the heat - and will fire up regardless of the incoming water-temp. The "solar" versions uses special controls to sense incoming water-temp and NOT fire up - but I don't know what sort of thermocouple and/or thermostat system they use. I've installed a few, but never had to take one apart to find out how they work. They do cost more.
PJH
05-19-2008 09:53:39
Your LP water heater, if it's like mine, will only heat water if it needs to be heated. If it enters the water heater already hot, it will not light the burner. I heat our water in an outdoor boiler before it gets to the water heater in the basement. The water heater never lights except at night when there is no demand at the faucet. The more hot water you use, the hotter it gets, but the heater burner still won't light because it's receiving already heated water from the boiler. My boiler has a standard temp/pressure pop-off valve on the line from the heating coil for the same reason that you have one on your LP water heater. Hope this helps - I'm not good at explaining things. . .
Nancy Howell
05-19-2008 09:35:10
My understanding of a thermocouple is that heat from the pilot light keeps it open which allows the gas to to come on to heat the water. If the pilot light goes out or the thermocouple fails, the valve to the gas shuts off preventing the gas from flowing to the heater when it would not ignite.
jdemaris
05-19-2008 08:59:56
I'm not sure I understand your question - but I've got three places that use wood to heat hot water, hooked in line with an LP hot-water heater.
Tank heater will work fine. Tankless will NOT unless you buy a special type made for it.
If you have a tank-type LP heater - it won't heat water coming into it that is already hot. But . . . you need to add a control at the wood-stove to keep the water from getting too hot before it gets to the LP heater - otherwise it can ruin the controls in it. Something like a Watts temp regulator works fine.
Now - if you have a tankless instant heater - it will not work unless it's the "solar" version. Solar version tankless heaters are especially made to be hook to preheated water and will not reheat it. A standard tankless heater will.
tractormarkb
05-20-2008 04:46:03
 Re: Wood Stove hot water in reply to jdemaris, 05-19-2008 08:59:56
Thanks as usual you all have been very helpful. My main concern was that the Water Heater would reheat the already hot water and waste gas. Thanks.
