Grease on clutch disks
Rick
09-19-2001 18:41:48
How can I remove gease from a clutch disc? I tryed puting them in boiling water for 1 hour but their is still some grease in the disk.Any suggestions will be helpful
Richard
09-25-2001 02:59:00
 Re: Grease on clutch disks in reply to Rick, 09-19-2001 18:41:48
Wiping most of it off then using brake clean works. I normally run the brake pads or clutch plates through a bead blaster to finish it off.
I have done this when I was in a bind (Lack of parts available or lack of funds) and everything turned out okay. Please be aware that the warnings have merit and it's not recommended unless there is absolutely no other choice.
Richard C. Rose
09-21-2001 15:58:10
I'm telling you, it's not worth it.
rollo
09-21-2001 05:26:26
Use MEK (methyl ethyl keytone). Buy it in the paint section of Lowe or a home store. It's safer than acetone (which will work very well).
Richard C. Rose
09-20-2001 16:12:46
Rick, oil and grease cannot be removed completely from clutche or brake linings believe me.
You will think they look clean but as soon as they heat up, more will come out.
You need to renew or reline the plate, the extra expence is justifiable compared to removing the clutche a second time.
Regards Dicko
Red Dave
09-20-2001 08:26:39
I would try a chlorinated solvent such as CRC's Brakleen.
Dean
09-20-2001 03:44:27
Acetone removes grease better than anything but read and follow the label directions. It's kinda nasty stuff.
the tractor vet
09-19-2001 19:53:28
Go get your self a coupel cans of BRAKE KLEEN that should do the track.
