trucker40
05-18-2008 09:05:23
Re: pto in reply to Elton Fancher, 05-16-2008 14:56:10
Like the others said you need to get the information off of the tag on the transmission.Chevrolet used a bunch of different transmissions,New Process,Spicer,Muncie,and others.After you get all the numbers you might be able to find one at a truck salvage yard just guessing maybe 50 dollars.You know it has to be shimmed to keep from knocking out bearings and to shift right,ask if you dont know how.If you are hooking this to a hydraulic pump I think you need a 2 way pump.I could be wrong,but If there is a 2 way pto,I dont remember seeing it.Reasonably sure I have not seen everything they put on a Chevy truck,but have not seen a 2 way pto,have seen power up/down pumps.There might be a pto that has a shaft that comes out of both the front and back,or that can be changed around from the front to back.Besides a salvage yard,a place that rebuilds transmissions maybe is a good place to try.Dont know where you are but at Kansas City there a place called Precision Built,and Truck Pro(Truck Pro has parts places all over the USA),and others,Custom Truck Parts,Arrow Truck parts,Places that sell truck beds like Binkley,Knaphyde,Heil all should be able to tell you something,but all of them will need the numbers off of your transmission and most likely the line setting tag of your truck which used to be inside of the glove box door,or on a tag somewhere inside the cab.
