Tool Talk Discussion Forum
OT - String Trimmer Bump to Advance NOT WORKING
Kirk Grau
05-15-2008 17:41:36
Bought a reasonably expensive Husqvarna string trimmer last year (try to get a cut above the consumer stuff without spending the cash for pro equipment, should probably just get the Stihl I was looking at). Wife used it yesterday and said the string advance was working, but today it will not advance when bumped. Anybody been into one of these to give me a hint what to be looking for?
Thanks,
Kirk
Stephen R. Horton-TX
05-20-2008 07:07:25
 Re: OT - String Trimmer Bump to Advance NOT WORKING in reply to Kirk Grau, 05-15-2008 17:41:36
Hi Kirk,
I've used blades and also those heads that you push small lengths of line into--none of them worked real good. When I bought my high dollar Honda string trimmer, I was gripping about heads not working to the dealer. He told me that the best bump head ever made is the Stihl. To prove it, he took the bump head off of my Honda and put a Stihl bump head on it. He was right. Its the first bump head I've ever owned that works the way I think it should. And its easy to load--my wife can reload it in less than 5 minutes. Now, all my string trimmers have Stihl heads.
Kirk Grau
05-18-2008 07:00:09
 Thanks, bought a replacement head yesterday in reply to Kirk Grau, 05-15-2008 17:41:36
Did not get a chance to put it on yet (nothing but rain in the forecast), but should get me back up and functioning. To those of you who suggested blades how much would they ding up all my fence posts?
Thanks again,
Kirk
Bret4207
05-17-2008 05:10:52
Mine gave me fits till I stared lubing it. A little Never-seize here and there fixed it.
BobReeves
05-16-2008 17:52:46
I take the bump stuff off and just run a piece of the heavy duty trim line through the two holes with a 1/2 knot loop over the shaft to hold it. Lasts as long as a reel full of the small crap and costs less.
Don L C
05-16-2008 16:09:59
Husqvarna = junk.....O turn lawnmore --every week either somthing broke. fell off or the front tires/tubes would get knocked off.....
don t-9n180179
05-16-2008 13:23:39
I know this wont help much but the 1st thing I do when I buy a new W-W is to toss that dang bump crap and put on a new head w/plastic blades. Then I buy 2 boxes of the plastic blades (12 blades in a box). As long as I stay away from concrete retaining wall blocks or chain link fence, the plastic blades last a while. Maybe 2 or 3 times around the yard, and the yard is 2 acres. Yea, I buy a $60 ryobi every 2 or 3 years. HTH.....YMMV.....don t. .....
jose bagge
05-16-2008 04:57:57
Kirk, my problem was just the opposite- I was going through about a mile of string every time I fired the damn thing up. I ultimately bought the metal blade used for trimming brush for it...doesn't cut as large a swath, but once it's on you are screwing around with it. No problems since!
DiyDave
05-16-2008 03:30:37
Why not just get a new head for it. Most of the high-end trimmers use the same left-handed metric head bolt. I have an old shindiawa pull and go head that has outlasted the shindiawa, 2 muryamas and will go onto my new stihl, as soon as the bump and go head goes in for rebuilding!
Mark - IN.
05-15-2008 19:04:37
I'm not familiar with a Husky, but if is like any other, has a spring loaded bumper. You didn't add or replace the string and forget the spring, did you? Don't laugh, I did that once with a problematic McCoullah I had, and that was the last straw for that baby. It was a pain in the rump since the day I bought it, but on the last day of its life, it was my fault...before I killed it real permanent like. I replaced the string, started it, bump, bump, bump and nothing. That was it...went flying like a javelin, broke the shaft and kill switch off, and the motor was spinning like a top in the yard until I grabbed it and pulled the plug wire. Then I went over and sat down where I restringed it, shaking my head. When I looked down, there was the bump, bump, bump spring right where I sat it when I opened it up. Oops, I messed that one up. Since then I've been through a weed eater that never really worked right since I got it, ran once, never again...and no, I didn't break it. It just only ever ran once, and is still in the tool shed. Then I got a Homelite that runs perrrrr rfect everytime, and has for years.
Good luck
Mark
Butch(OH)
05-15-2008 17:56:54
After making sure the works are not clogged up with grass goo and the spool is wound up correctly the next thing to check (believe it or not) is how old your line is. Local shop told me it goes bad with age and I thought he was joshing me but found out this spring he was not, old string will bind together in the head LOTS easier than fresh opened stuff. I have had Stihls for three years now and their head is the best I have used, few parts, simple to load and works far more often than the other trimmers I have owned. Maybe the Husky will blow, LOL.
Kirk Grau
05-15-2008 18:21:20
 Re: OT - String Trimmer Bump to Advance NOT WORKING in reply to Butch(OH), 05-15-2008 17:56:54
Spool and string are not bound up at all.
The "bumper" is just fixed rigidly in place. I am pretty sure it would compress a little before and release the string.
My string is old (left over from last year), but I think I have other issues.
Thanks,
Kirk
mark
05-15-2008 18:39:22
 Re: OT - String Trimmer Bump to Advance NOT WORKING in reply to Kirk Grau, 05-15-2008 18:21:20
There are two ways to approach buying a weedeater.
The one I have chosen is to go buy the disposable $69 jobs like Lowe"s sells, use them for 3-4 years or until they begin to act up and then toss them. Amortize the cost of owning a high dollar rig over it"s expected life and see if it costs less than $25 a year to own. That"s an eye opener! Other than snob appeal, it"s highly unlikely you"ll get your money"s worth. Before some Bozo chimes in about how he fells timber with his saw blades and tills his garden and so forth..... we"re talking a string trimmer here.
If you insist on spending money, buy a Shindaiwa, they seem to outlast the rest.
Butch(OH)
05-15-2008 18:59:04
 Re: OT - String Trimmer Bump to Advance NOT WORKING in reply to mark, 05-15-2008 18:39:22
You are correct in that most dont need a high end trimmer. We do some lawns and ours run some hours. Lack of any kind of maintainance and crap old fuel kills most trimmers and kills low and hi buck units with no discrimination. I like Shindy"s myself, have two saws but no trimmers. The saws are awsome.
Kirk Grau
05-15-2008 18:46:00
I can buy into this argument pretty easily (used it myself), except that I was only getting a year (maybe less) from the el cheapo units. We have most of a mile (half mile both sides) of fence along a driveway that gets trimmed alot.
mark
05-15-2008 18:59:55
 Re: OT - String Trimmer Bump to Advance NOT WORKING in reply to Kirk Grau, 05-15-2008 18:46:00
Kirk,
I don't have a driveway like that, but I do have 2 1/2 acres of yard, several buildings, and a ga-zillion fruit trees and bushes, walks and flowerbeds to trim around. I'll typically burn 4 tanks through my weedeater by time I am finished. The engines never fail, I've tossed lots of good 2 cycle engines in the garbage. It's always the bump heads that go south. I tried repairing them. At about $20 to fix the stupid head...that's almost 1/3 the cost of the unit. Then the throttle cable gets worn or the gas tank begins to leak or the recoil starter goes limp. I just bought another $69 weedeater this spring...used the other one 3 years. I have lived long enough to learn that trying to squeeze a nickel until it squeals causes more headaches than it's worth. Weedeaters and electric hand tools are disposable items to me. The day it causes grief, is the day it hits the garbage can.
