Tool Talk Discussion Forum
Wiring a Welder
MCL
05-15-2008 17:14:40
What size wire would I use to run from breaker box to welder plug? For now it will be about 4 feet from box. Someday it may be about 25 feet away. I plan on using a 50 amp breaker. Thanks.
Stan in Oly, WA
05-15-2008 17:50:08
 Re: Wiring a Welder in reply to MCL, 05-15-2008 17:14:40
Hi MCL,
The instructions with the welder will specify the size of breaker that is required for the welder to run at full capacity. The breaker size will dictate the size of wire to each outlet or appliance on that breaker.
I think that by code a 15 amp breaker requires 14 gauge wire, 20 amp requires 12 gauge, 30 amp is 10 gauge, 40 amp is 8 gauge, 50 amp is 6 gauge. You can always use larger gauge wire than is required.
Welders regularly run on smaller breakers than their specifications call for because they are not usually run at full capacity. That doesn't mean that this is a good idea, though. For one thing, breakers are not intended to be tripped repeatedly, and doing so may damage them or degrade their capability.
All the best, Stan
old
05-15-2008 17:25:45
What type of welder. If its say a Lincoln buzz box type or one like it nothing less then #8. The long you go the bigger you want and it never hurts to use bigger then need but it does hurt to use smaller. I think with mine I use #6
