Tool Talk Discussion Forum
Finishing Off Garage With OSB
Glenn F.
05-14-2008 13:52:55
I'm gearing up to finish off my attached 22'x34' garage. In the process I'll be wiring, insulating, sheathing and painting. I will also be installing a "Modine" heater, but possibly not for a year or two yet.
While I like the look of sheetrock, I think OSB sheathing (currently on sale) will serve me better. However, I want it to look as nice as possible.
Regarding OSB sheathing, a few questions come to mind:
1) What fasteners are recommended, nails or screws?
2) Is 7/16" suitable for a ceiling with 18+" of insulation?
3) Is there any way of finishing off the seams, (caulk, flexible joint compound, etc.)?
4) What paint is recommended for the first coat?
Thank you,
Glenn F. (Northeast Wisconsin)
John - OH
05-16-2008 19:46:41
 Re: Finishing Off Garage With OSB in reply to Glenn F., 05-14-2008 13:52:55
To answer your questions
1. screws definetly 1 5/8" or even 2"
2. is 7/16" heavy enough for 18" of insulation, for fiberglass, yes. For blown in, not sure on that.
3. Painters caulk works great for smoothing/ filling seams.
4. Painting first coat must be done with an oil base primer, something like Kilz. Latex primer will not work, the OSB will bleed through even after 3 coats. I have a brother that can tell you about that, bad paint info from a box store employee, but that"s another story.
OSB makes great shop walls in my opinion, heck of a lot more durable than drywall. When done right will look great when done. Just my 2 cents.
Leland
05-15-2008 05:54:39
my new garage has 7/16's OSB on walls and cieling and I just used 1 1/2 drywall screws without any problems . Just put screws about 12" apart on cieling and you will be fine. As far as paint I have never saw a good finish on OSB just leave it plain after all it's only a garage not a palace .Spend the paint money on something more important .
jose bagge
05-15-2008 02:28:31
have you thought about a suspended ceiling? easier than drywall, fireproof...I did it in my garage myself and it worked out well
Gordon in IN
05-14-2008 21:25:56
I had a lot of trouble with "dry wall screws" in OSB. The heads "popped off" easily. I went to "decking screws" that were cad plated or galvanized and were one or two sizes larger in diameter. They worked MUCH better. Instead of "countersinking" the OSB just run the phillips bit into the OSB before starting the screw. The 5/8 inch FIRE RATED DRYWALL is nice to work with, is stronger than non-rated drywall and MAY be required by code. Even if not required, the fire rated drywall really does provide good fire protection. Good luck in whatever you decide.
NE IA
05-14-2008 20:15:59
You probably only would like to do this once, so therfore get 5/8 min. if you are using 18 inches of insulation. If you buy the better quality OSB it will be uniform. There are different grades, and the color of the paint on the sides tell the story. The ones that are a different thicknes can be bought cheaper than the better grades. Usualy the big box stores sell the iregulars. Now look on the printed side. Usualy other than the 9 foot stuff there is a story to read. One of the most important words are 1/16 gap on sides and 1/16 gap on the ends. A simple nail will give you the gap---1/16 for expansion. You sometimes hear about OSB bulging, well again--there is a reason it is stamped on each sheet.
We sometimes make batten strips out of the scraps. If you like painted then paint the ceiling first or just seal it then paint the batten strips a different color if you desire. --while on the saw horses before you rip them saves alot of time as well. Give them the second coat and paint the dedges the second coat, and then nail them on.
I am a big hard headed old timer that actualy think that OSB was once in its most usable state when they chipped it up, and before adding the rosin to make sheets out of it. Mom could spread it around the flowers and I could nail real plywood on the buildings. Those days are gone and we are forced to use OSB instead of plywood.
As others have suggested --most building codes do not call for OSB for a fire stop, rather it is sheet rock. Your insurance Company, now or in the future may make some demands on your OSB idea.
Next question is have you ever been around a building that burned down? Yea, it can happen to you---price out 5/8" sheetrock and give it some serious thought. Regardless of your decision rent or borrow a sheet rock jack. Sheet rock jacks make good friends.
If you are going to paint it make use of your pre painted 16" OC and 24" OC lines--rough side down. That saves alot of time. They will always be 16" on center and the center line will be for your rafter two foot spacing.
PJH
05-14-2008 18:53:43
I helped my son seal his 30 X 50 pole barn with OSB. There were some places, for whatever the reason, the OSB wouldn't match well in between the joists. One piece would be up, while the adjoining piece would be down. We would use a short piece of scrap blocking in those areas to align the surfaces together. Also, a carpenter friend advised him to lightly bevel the edges with a small block plane. It kinda hid the smaller edge problems, and didn't take long - one trip around each piece. We used a screw shooter to install it at his place - I used a nail gun in my shop, I'm not as finicky. . . Don't know about painting - never got around to painting it before it got filled with good "junk".
Bus Driver
05-14-2008 17:49:47
Do be sure that the drywall is not required. Years ago, I had some really rough plywood used to cover the walls in a workshop. I primed it with aluminum paint, not the asphalt-based type. Worked very well.
CNKS
05-14-2008 17:33:43
You can cover the seams with what I call "furring" strips, but the contractor used 1 x 2's in my garage. I prefer thin narrow strips, though. I don't think it makes any difference which side faces in. It's going to be rough any way. I believe the rough side is less prone to peeling. In my new shop building I have them both ways -- guess I'll find out.
big fred
05-14-2008 17:29:34
I put an office in my garage, and utilized part of a shear wall. The shear wall was sheathed both sides with 7/16 OSB. To match up to it, I used 1/2 drywall, taped the joint just like a drywall joint, and skim coated the OSB with mud, sanded, then skim coated it again. After texture and paint, you can't tell any difference between the OSB and drywall.
fergienewbee
05-14-2008 16:32:02
For OSB, 1-1/4" course drywall screws are fine. I agree, at least 1/2" (5/8" even better) on the ceiling. I assume trusses are 2' on center. Sheetrock ceiling would give better light reflectance than painted OSB. Sheetrock may also be required on ceiling to meet code. In MIchigan we need sheetrock between house and garage.
Larry in Michigan
John730D
05-14-2008 16:14:11
Did my garage this winter with OSB. Should use 1/2 inch minimum on ceiling. Fastened mine with wire staples in an air staple gun. Works great and invisible. Get it where you want it before you staple because they're almost impossible to remove. Don't ask how I know.
Bryan in Iowa
05-14-2008 15:45:53
shiney side inside , 1 5/8 drywall screws . Don't worry about countersink . If rough spots,just touch up with belt sander . Primer/sealer coat first as this stuff soaks up lot of paint . I just finished inside of garage with it myself. Also thought about just doing skin coat of plaster,,but looked ok after paint.
Bryan in Iowa
05-14-2008 15:47:51
 Re: Finishing Off Garage With OSB in reply to Bryan in Iowa, 05-14-2008 15:45:53
Almost forgot the biggie !! check with inspector to see if OSB meets code and fire requirements !!!!! Sucks to cover all that up with sheetrock .
RobMD
05-14-2008 14:41:32
I'd seal the seams with a caulk that is paintable and flexible.. some sort of silicone. I like that DAP ALEX PLUS stuff, it's paintable and you can put it in with a putty knife.
jlmtractor
05-14-2008 14:28:43
the best way i would think to do would be to put the sealed part towards the inside of your garage so you get a nice smooth look. and to hold it up i would drill some countersunk holes so your screw doesnt splinter it. but to seal the seams that would have to be some an experimental phase because i would have no idea what to seal them with
showcrop
05-14-2008 21:43:45
 Re: Finishing Off Garage With OSB in reply to jlmtractor, 05-14-2008 14:28:43
Don't worry about code. worry about your life! Especially on the ceiling I have seen fire travel along a ceiling like that faster than you can run! sheetrock has saved lots of lives. consider OSB down low where it may take abuse better, but use rock up higher and get flame retardent paint for the OSB.
36 coupe
05-17-2008 04:15:44
 Re: Finishing Off Garage With OSB in reply to showcrop, 05-14-2008 21:43:45
Work shops around here often use aluminum roofing on shop ceilings.Hard to find aluminum roofing now.
