Tool Talk Discussion Forum
OT - Compac Presario 5000
Mulerider
05-13-2008 19:25:58
Anyone familiar with this computer? It is a 2000 model and HP no longer has any info on it (imagine that). I am trying to get open the case to change Hard Drives. I have one side off. The next step is getting the front off, and I am afraid to force and break it. Anyone have one of these? Thanks for any help.
rhouston
05-14-2008 05:49:55
 Re: OT - Compac Presario 5000 in reply to Mulerider, 05-13-2008 19:25:58
Each one is different in how they come apart. I've had Presarios that pull the whole chassis out the back and ones where the drive bays come out the front as a whole unit. There should be clips on the front bezel if it was made to come off. If you get it loose but cannot get it by the drives then the drives have to come out first. You should be able to tell by how the drive bezels clear the front bezel of the case. If they push up against the back of it then the chassis or drive bays come out the back. If they are in front of the bezel then the drives have to come out first. Enjoy some of those cases are a real bear to figure out. Look on the bright side at least it isn't a Laptop
By the way Presario 5000 is not a complete model # There should be a tag on the back with the actual model number. Presario 5000 is a family not a model
soundguy
05-14-2008 05:22:44
I'm with sam#3.. check for locking tabs on that plastic front nose. i've had presario's before .. and that was what they were always held on with.
soundguy
old bc
05-13-2008 21:17:41
Try the link below. Copy and paste it into your browser.
old bc
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03429&lc=en&cc=us&lang=en&rule=38347&product=92874&dlc=en
Mark - IN.
05-13-2008 20:43:15
My mother has a Compac Presario, about the same year, and maybe even the same model. Heck, you might even be running Windows ME off of Compaq's licensed recovery CD at that. After the second time of trying to reload her ME OS from that recovery CD, the heck with that, went out and bought her a copy of XP Home Edition for a little over $100 way back then. A copy of XP Home Edition goes for about $175 now and is getting harder to find, and is so expensive because of supply and demand thanks to Vista. I had to change the hard drive in hers years ago when it was still under warranty. As I recall, did have to do it through the side panel. Don't recall taking the front off, other than maybe the plastic cover, and not sure if I even did that...way back when. If I did have to take that plastic cover off, I'm thinking its locks would've been accessable after took the side covers or shell off. But I don't see pulling a hard drive through the front of a chassis or having mounting screws through the front of the chassis. Whatever I had to do back then, I didn't break anything, and I'm like a bull in a China shop, so can't be that tough. I'm not where I can see Mom's PC, so can't say for sure. Take another closer look. I'm trying to imagine the hard drive mounting. Usually with that style of hard drive, are two screws on each side that mount to a chassis or tray of its own, and the trays usually or might have a locking screw at the rear of them to hold or lock them in place in the larger computer chassis. I honestly don't recall having to take that huge front off, but maybe I did. Sure there aren't maybe clips holding the hard drive tray or mounting in place if not a locking screw at the rear? The newer PCs are even easier yet...side cover slides off, no screws, just a locking tray, power cord, and ribbon cable SATA or otherwise.
Its time you replace that pentium 2 processor anyway. The newer softwares (think Vista too) are written so crappy these days, need at least a pentium 4 to load a program in under a day because are so crappy in the area of quality control. I have an older pentium 4 (antique now), and mentioned to an IT guy how slow loading newer programs are, and like frozen mud on Mom's pentium 2. His response was the processors are good, software anymore is junk and requires the faster more powerful processors to make up and cover for their...crappyness. Anymore, need a dual core processor to run programs, and they make my pentium 4 look as fast as frozen mud.
Good luck.
Mark
Sam#3
05-13-2008 20:22:00
I didn't have a Presario but I did have a couple compac desktop models and the case slid off the back. As I remember the case was held by two screws on the rear and the front edges used locking tabs. The front formed part of the drive bays and wasn't removed.
I hope this helps. Sam
Mulerider
05-14-2008 07:41:25
 Re: OT - Compac Presario 5000 in reply to Sam#3, 05-13-2008 20:22:00
THANKS TO EACH ONE THAT RESPONDED. AFTER REMOVING THE SMALL PLASTIC COVER, ALL OF THE DRIVES PULL OUT THE FRONT. MANY, MANY THANKS.
