Tool Talk Discussion Forum
Unidentified floor jack, Help!
dave guest
05-12-2008 18:24:58
Come across floor jack, needs handle. Only ID is WWW and color is all yellow. Handle goes over square shaft down to gear and valve. Wonder if it's worth buying a handle. I could make one but it would be project since I don't have lathe. Thanks again for any suggestions.
rockyhawaii
05-13-2008 09:50:42
 Re: Unidentified floor jack, Help! in reply to dave guest, 05-12-2008 18:24:58
Dave, I had one of those Chinese jacks with the square hole in the handle. I still have the hanlde and took a look at it. I think you could cut the square hole in a couple of thick washers with a Dremel and weld them into the bottom of a handle.
Lefty
05-13-2008 06:24:51
Could you use square tubing to fit?Can't seem to get a mind picture on fitment.
Ebfarmer
05-13-2008 05:03:05
Parts for jacks are getting very hard to come by. Almost all the old manufacturers(Walker, Omega, Port-A-Power, Hein-Warner) have been bought out by Shing Fu, and they do not carry parts for the old models. You will more than likely have to make the handle yourself. If the rest of the jack is good, and you can make the handle, it is probably worth the effort.
