Tool Talk Discussion Forum
Stihl MS250 chainsaw
woodbutcher
05-12-2008 13:36:15
I've posted on this board before with good things to say about the Stihl chainsaws I've owned. I've bought this MS250 new in 2004, and I like the weight and balance of it. It runs good, but lately I've noticed when I store it for the night that when I go back the next day it looks like the Exxon Valdez was parked there. I traced the problem to the filler cap. It's a rinky-dink plastic vented plug with a half-circle hinged flap that is supposed to seal it when the flap folds flat. Surely the larger saws have a better way to cap the reservoir. My old .031AV sure did.
Chuck - WI
05-13-2008 06:01:41
 Re: Stihl MS250 chainsaw in reply to woodbutcher, 05-12-2008 13:36:15
Make sure you clean the area around the cap / gasket when you close it .. mine would get small wood chips on the gasket .. and the same leak
RobMD
05-12-2008 23:06:39
It's what happens when a reputable manufacturer decides to schitt-ify things for econmomical reasons.
We're all constantly having to go out of our way to keep new things from leaking, breaking, or falling apart on us.
Nothing new.
PJH
05-12-2008 19:41:01
Just get a new cap - one of my Stihls leaked in the case too, and a new oil cap made it like new again.
I've got a Stihl 039, and the day I bought it, the dealer insisted I start it in his presence. I grabbed it and proceeded to "drop" start it, and he panicked. He insisted I set it on the floor, put my big foot in the handle, and crank it. When I did, the gas cap popped off and all the fuel dumped out on the floor and ran under a lit kerosene heater. I thought it was all over, but we mopped it up, franticly, without it igniting. A couple of weeks later, I got a recall letter from Stihl - defective gas caps. . .
MGTPa
05-12-2008 17:35:05
Go to eBay and type in, Stihl MS 250 Oil Cap, you can get a new for 10 bucks. Solve your leak problem. It's a good design but after alot of usage it will start seeping oil. My son has a MS 290 and just loves it. He cuts a lot of wood and hasn't had any problems with leaks.
Brian in MI
05-12-2008 16:01:55
I have a Sthil MS 180, and it has regular caps for the oil and fuel. These caps have a slot in them to tighten/loosen with the spark wrench
ltolson
05-12-2008 17:08:26
 Re: Stihl MS250 chainsaw in reply to Brian in MI, 05-12-2008 16:01:55
Same saw same problem. Great running saw just need to remember to lay it on its side. Bad design.
Larry
dave2
05-12-2008 14:27:02
Same here! Whatcha got in mind to fix it? My wife bought me this neat Stihl wooden box that holds the saw and a bunch of goodies that I don't want to use because of the oil. So far, I have just been keeping about an inch of sawdust in my plastic case.
Dave
woodbutcher
05-13-2008 04:27:08
 Re: Stihl MS250 chainsaw in reply to dave2, 05-12-2008 14:27:02
Thanks for all the responses. I guess I'll check Ebay after trying to tighten the old cap and make it seal.
Butch
