Tool Talk Discussion Forum
Rate of acetylene use
Stan in Oly, WA
05-10-2008 18:17:04
If the rule of thumb is to use acetylene at a rate of no more than 1/7 of the bottle per hour, is that the same as saying 1/7 of the tank pressure of a full bottle (which is usually around 400 psi, isn't it?) In other words, can you use about 60 psi or less worth of acetylene per hour regardless of the size of the bottle or the amount that's left in it?
Thanks, Stan
504-2
05-11-2008 17:04:28
 Re: Rate of acetylene use in reply to Stan in Oly, WA, 05-10-2008 18:17:04
The total C.F. of the tank is stamped on the top of the tank(around 135cf) and check the specifications on your tip for maximum flow. And if you lay a tank down stand it up for an hour or two or you will be rebuilding the regulator.
MarkB_MI
05-11-2008 03:06:11
I think it pretty much has to do with tank volume, not the volume of gas left in the tank. Acetylene in the cylinder is dissolved in acetone, and the volume of acetone in the tank is constant. The bigger the tank, the faster the acetylene can be released from the acetone.
Also, I don't think you should rely on the pressure in the cylinder as a measure of how fast you are drawing it down. Just look up the tip you're using on your torch manufacturer's tip chart to see what its flow rate should be.
Pappy
05-10-2008 21:23:32
What is that recommendation that you not use more than 15 PSI on your acetylene?????
Billy NY
05-11-2008 05:42:20
 Re: Rate of acetylene use in reply to Pappy, 05-10-2008 21:23:32
I believe that Acetylene, becomes unstable above 15PSI. The Acetylene regulator on my rig, mfr'd by Smith, will not go above that, though I set it much lower, depending on what I'm doing.
Another one is not laying the Acetylene tank on its side, if so, it needs to be upright for awhile, like maybe over night, though I play it safe and keep em upright, not sure how that works, but do know enough to respect volatile compressed gases and those tanks.
Redhot Stuckrod
05-10-2008 20:14:05
Well, here's what I think. Pressure falls quicker the less gas is in the tank. Meaning that one cubic foot of gas would take alot more pressure from an almost empty tank than it would from an almost full tank. That's why you tend to have to turn up the regulator a bit ev'ry day. I would go with a more conservative number just to be on the safe side. If I had my own torch I'd keep a log and find out for sure.
dave guest
05-10-2008 20:10:15
Whole lot less than oxygen. Got a tank bout 10 years old. Used about 15 tanks of oxy.
Slag Throughboot
05-10-2008 19:45:03
But whatever you figure it out to be, you can rest assured that is with a new tank under perfect conditions.
I've always found that when I need to heat a big chunk of metal with the rosebud, that unless I am at the local college, or another industrial site with the largest bottles, or multiple tanks ganged together, it is going to be a tough go getting enough out of the bottle fast enough.
RobMD
05-10-2008 19:17:46
i think its more the volume (size) than the pressure...
Stan in Oly, WA
05-10-2008 20:53:23
 Re: Rate of acetylene use in reply to RobMD, 05-10-2008 19:17:46
Hi Rob,
I agree that it's ultimately about the volume, but the only available means of measuring it are the tank's psi and its weight. I've never heard of anybody weighing the tank as they use the gas, so that leaves only the pressure as measured on the gauge, doesn't it? It makes me wonder if it isn't one of those things where all you can do is to do your best and it either works or it doesn't.
Anybody ever had acetone get into their acetylene regulator that wasn't the result of the bottle being on its side at the time or recently?
Stan
Redhot Stuckrod
05-10-2008 22:06:10
 Re: Rate of acetylene use in reply to Stan in Oly, WA, 05-10-2008 20:53:23
I think a person could install a meter to read volume used. Kinda like a gas meter on a house, gaspump etc.
jose bagge
05-11-2008 05:37:16
 Re: Rate of acetylene use in reply to Redhot Stuckrod, 05-10-2008 22:06:10
That's what a flowmeter on a MIG outfit does, right?
