Tool Talk Discussion Forum
Cordless broom power supply
redtom
05-08-2008 18:42:11
My wife's Swiffer vac cordless broom's power supply broke the wires right at the little round plug where it goes into broom. It is 9volt 150 mA. I can order new from company but found many on ebay that are 9v 200 mA and much cheaper. Question: how much difference to batteries between the 150 mA and the 200 mA charger/power supplys.
mjbrown
05-09-2008 06:50:35
 Re: Cordless broom power supply in reply to redtom, 05-08-2008 18:42:11
When I saw the heading I thought this was a joke but I see I was wrong. All my brooms are cordless. I didn't know there were powered brooms!
big fred
05-09-2008 10:17:43
 Re: Cordless broom power supply in reply to mjbrown, 05-09-2008 06:50:35
If it's cordless, yer mother-in-law ain't so tied down...
soundguy
05-08-2008 20:48:32
what about getting a new plug end and just do 2 minutes of soldering and then a quick heat-shrink job and be done with it. ratschack has dozens of plug ends..
soundguy
KEB1
05-08-2008 20:33:32
Whether the larger current capacity would affect the batteries or not is a function of the battery type and whether or not the broom has a built in charger.
The typical wall wart charger for a NICAD battery pack depends on the internal resistance of the charger itself to limit current through the cells during charging. Too much current will overheat the cells and reduce their life. NICAD's require a small constant current to maintain a full charge.
A couple things to check. First, look at the data plate on the broom and see if it says what the battery voltage is. If it uses a 6 volt battery pack, then there is most likely a charger circuit between the 9 volt input and the batteries, and the larger current capacity won't hurt a thing. Also, if the transformer output is AC and not DC, then there's at least a rectifier circuit between the power input and the batteries, and you're probably also fine.
Assuming that you match AC/DC and the connector polarity (if applicable), just plug it in, let the batteries charge for a while, and see if they get warmer than usual. If they don't get warm, then all is well. If they do get warm, you can still use the higher current supply to charge the batteries, just don't leave it plugged in all the time. Easiest way is to put it on a timer so it charges for some short period of time every day.
Keith
PJH
05-08-2008 19:21:28
Make sure the polarity is the same as the old one. Also, you'll find both AC and DC supplies. Make sure they match.
