Don't have a lot of experience with arc welding, but do have some experience running one off a generator. Like you, I'm still waiting to get enough power to the shop to run a welder (hopefully this summer). Anyway, I use a Troy-Bilt 5500 watt generator when I need more power than a long extension cord can provide. I have a PowerKraft 230 amp buzz box welder that doesn't seem to like to run at all on the generator, no matter what current I set it to. It'll eventually trip the circuit breaker on the generator if I set it more than about 125 amps. I also recently acquired an ancient Airco AC/DC welder, and it runs great on the generator. I've run up to about 150 amps AC and over 100 amps DC with no problems at all. Nice smooth arc, easy to start and no problems with the rod sticking (except when I shove it too far into the puddle). I suspect the Airco has a much better power factor, which is probably why it runs better on the generator. I have no idea if the distortion on the output of the generator impacts the buzz box transformer or not, but that's another possibility. Realize this doesn't really answer your question, but my experience with an AC welder is very similar to what you've seen. By the way, at least in my case, its not the length of the cord. I bought a connector and plug the end of the welder cord directly into the generator. Keith
