Tool Talk Discussion Forum
HF 9200# Load Binder
Glenn F.
05-06-2008 09:59:52
Item# 5511, 9200# ratcheting load binder, currently priced at $24.99. Anyone have problems with these units?
Thanks,
Glenn F.
Glenn F.
05-07-2008 18:40:17
 Re: HF 9200# Load Binder in reply to Glenn F., 05-06-2008 09:59:52
As always, I appreciate each of your responses.
Domestic load binders are increasingly hard to come by. Made in China, is made in China, no matter where it is purchased.
I have read (and will read again) the WI state regulations, but even if it's not required, I will be binding with four grade 70 chains, each one capable of holding the entire tractor weight.
Thank you,
Glenn F.
Glenn F.
05-07-2008 18:41:33
 Re: HF 9200# Load Binder in reply to Glenn F., 05-07-2008 18:40:17
Oops! I accidently combined my responses for both of my threads under this one.
Glenn F.
Bret4207
05-07-2008 16:28:12
Over center binders are most certainly legal up to any weight with in the working load limit of the binder. Despite my caution at HF quality, if the binder says it's good for 9200 WWL then thats what we have to go by.
Sincerely,
Tpr. Bret, your local DOT Trooper.
JT
05-08-2008 18:06:36
 Re: HF 9200# Load Binder in reply to Bret4207, 05-07-2008 16:28:12
Brett,
where are you a DOT cop? The Illinois State police are even trying to make life miserable for commercial landscapers saying they need to bind a lawn mower to their trailers, 4 binders on each mower. I guess they are getting bored with the real violators.
Jim
john *.?-!.* cub owner
05-07-2008 13:31:06
 Re: HF 9200# Load Binder in reply to Pollack Pete, 05-06-2008 09:59:52
IH2444 said: (quoted from post at 20:31:42 05/06/08) Are the snap over types still legal per DOT ?
They are up to a certain load, but they are required to have something holding the handle in place so it can't swing loose (wire, clip, etc).
marlowe
05-07-2008 10:33:48
you guys don't buy many binders do ya just bought 12 and could not find ONE made in the USA all china or some other third world country so HT got the sale. can't leave them on the trailer for 5 minn.or they are gone. last week on the job parked trailer at site and 2 hr. latter chains and binders gone and i was there all the time never seen them dirty #%&%!*&+
Davis SC
05-07-2008 18:39:08
 Re: HF 9200# Load Binder in reply to marlowe, 05-07-2008 10:33:48
I was at our Northern Tool store a few weeks ago, and they had both US and China load binders. The US ones were Columbus McKinnon.. Yes they cost more than the Chink ones, but worth the difference, IMO..
RustyFarmall
05-07-2008 17:58:00
You are 100% correct. I've even shopped for them at genuine truckstops. Not a single one was "made in U.S.A." Might as well buy the least expensive binder you can find.
JT
05-07-2008 06:57:01
Harbor freight stuff will work fine, until you get in an accident and someone gets hurt. The thing you have to keep in mind, you get what you pay for, you buy a cheap chain and binder, then ..... .., you fill in the blanks. Is your equipemnt not worth the couple-three hundred dollars you would spend to get good chains and binders?
Don L C
05-07-2008 04:31:34
I have had no problems,HF chains and binders work fine.....
Glenn F.
05-07-2008 05:44:47
 Re: HF 9200# Load Binder in reply to Don L C, 05-07-2008 04:31:34
Do they sell grade 70 chain?
Glenn F.
Glenn F.
05-07-2008 14:09:23
 Re: HF 9200# Load Binder in reply to Glenn F., 05-07-2008 05:44:47
Just checked. Harbor freight has #70 chain in 5/16", but not in 3/8". 5/16 is rated at up to 4700#. I need at least 3/8".
Glenn F.
IH2444
05-06-2008 18:31:42
Andy C
05-06-2008 14:18:22
Got hit going thru an intersection a few years ago. Trailer with 8000 lb skid steer on it (4 chains and HF ratcheting binders holding things down) rolled twice. We released all four ratchets to separate the skid loader from trailer and I am still using them today. Enough force to bend two of the wheels on the tied down skid steer! No straight metal left on trailer.
Mike M
05-06-2008 11:08:07
I have a bunch of them and have not had any problems with them. I like them alot better than the snap over type and won't go back.
RustyFarmall
05-06-2008 11:47:32
 Re: HF 9200# Load Binder in reply to Mike M, 05-06-2008 11:08:07
Mike, it depends on what you are cinching down. If it has rubber tires, I like the over center binders because you can squish down the tires and the load will stay right there. If the load is a piece of machinery that has no "give" to it, the ratcheting binders are the only to go.
Mike M
05-06-2008 12:29:11
 Re: HF 9200# Load Binder in reply to RustyFarmall, 05-06-2008 11:47:32
???? You can keep turning that ratchet handle until the tires are squished. I have heard way too many horror stories of pipe handle extensions of people getting knocked in the noggin and of upon releasing the load let loose and fell on them. Way safer to loosen slowly with the ratchet.
Silver Pig
05-06-2008 10:29:00
Typical HF Chicrap, may or may not work, or even come close to its rated load.
The Federal Govt. and/or State DOT need to make new rules making any use of Chicrap chains, boomers, straps, or other load retaining device illegal.
Those that are too cheap to buy quality product that will perform at their rated capacity, could be fined, or sued, into compliance.
02XLT4X4
05-07-2008 10:27:29
 Re: HF 9200# Load Binder in reply to Silver Pig, 05-06-2008 10:29:00
Silver Pig said: (quoted from post at 10:29:00 05/06/08) Typical HF Chicrap, may or may not work, or even come close to its rated load.
If you are within the weight rating on the side of the binder and it was in good shape I doubt you would get any more grief after an accident than if you had a equally rated high dollar one made in the USA.
