Tool Talk Discussion Forum
Nickel Boron.What is it ?
Earl -IL
05-05-2008 17:07:21
Is this a chemical treatment to steel or is it a steel material?? Where can you buy 1080 sheet material? Thanks Earl
36 coupe
05-06-2008 02:43:03
 Re: Nickel Boron.What is it ? in reply to Earl -IL, 05-05-2008 17:07:21
It has been used on horseshoes to provide a slip resistant surface.Its applied with a torch.Very hard material.
Earl -IL
05-06-2008 19:03:11
 Re: Nickel Boron.What is it ? in reply to 36 coupe, 05-06-2008 02:43:03
Thanks for your reply.
rockyhawaii
05-05-2008 18:49:23
My understanding is that it is a plating applied to metal, similar to chrome. Depending on the application, it uses varying amounts of copper, boron, and nickel. The Naval shipyards use quite a bit of it, and it is considered a high-risk item for theft.
Earl -IL
05-06-2008 19:04:24
 Re: Nickel Boron.What is it ? in reply to rockyhawaii, 05-05-2008 18:49:23
