Tool Talk Discussion Forum
FARM TRUCK Road Ranger RT 613
lenray
05-04-2008 15:47:04
I have this older farm truck IHC PAYSTAR 5000 with a Fuller Road Ranger RT 613.
Where do I check for the transmission oil level.
Is there more than one place to check and fill??
Thanks for any help.
Charles (in GA)
05-04-2008 20:33:32
 Re: FARM TRUCK Road Ranger RT 613 in reply to lenray, 05-04-2008 15:47:04
One other lube manual
Link
Charles (in GA)
05-04-2008 20:30:55
Here is the lubricant bulletin.
Link
Charles (in GA)
05-04-2008 20:22:23
http://www.roadranger.com/Roadranger/index.htm
Haywood
05-04-2008 16:04:00
Look on the Side of the case about half way up for a Large pipe plug with a square head on it.
Fill it till it starts to run out.
Use 50W motor oil in in Fuller Roadrangers.
Or Drain and use Synthetic. The Eaton Fuller Roadranger Website has a Synthetic Spec you can look up. It only fills from that one location.
HD
05-04-2008 17:10:14
 Re: FARM TRUCK Road Ranger RT 613 in reply to Haywood, 05-04-2008 16:04:00
DO NOT ADD 50W motor oil to a fuller unless U want to rebuild it!! There is a specific 50w transmission oil IH dealers carry it, also comes on synthetic. HD
lenray
05-04-2008 16:32:47
Thanbks Haywood
I found the large plug.. There is one above the PTO pump and another one the same size about 8 inches farther back on the same plain.
Do they both service the same compartment???
Thanks for your time.
len
