Tool Talk Discussion Forum
Use spinning pinion as ground drive?
jose bagge
05-04-2008 05:53:08
I think the kick up is back over the rear wheels, so you should be able to use the frame rail material- weld in a good cross member right behind the knotch. I've always though about using the spinning pinion on trailers like this as some kind of ground drive PTO- rotate it 90' and make a ground drive mower?
