Tool Talk Discussion Forum
How to set up garden plow---cross post
ldj
05-02-2008 16:39:12
I cross posted this from garden tractors forum here.
I have read everything I can find on the net and at the Brinley site. My garden tractor is a Homesteader with a Brinley plow. This tractor is the one made in Clinton Arkansas, Not the Allis Chamlers. I read that the plow should have a curve in the cutting edge called suck. Mine looks to be a little more than the instructions say. My ground hasn't been plowed in years and has grass on it, Ie. it has been part of my yard. The plow will go down about 1 1/2 or 2". The ground is heavy black ground and it may be a little wet but I don't think so. It will go down just so far and then the plow kick down in front and up in back with just front few inches (4 or 5") of the plow digging a trench in the ground. How can I make this plow engage the ground more and plow as it should. Is my ground condition just not right? Have I got something set all wrong. I have turned it steeper and more flat and can't get it any better. when I change the setting it does change for the worse the way it plows.
If I understand correct the plow should go in the ground and to the proper depth by its self ie. I don't need to put any down pressure on it, just being sure the sleeve hitch will go down far enough.
L.D.
mike mitchell
06-28-2008 16:47:07
 Re: How to set up garden plow---cross post in reply to ldj, 05-02-2008 16:39:12
is your tractor the one with the 15inch tractor type tires in the rear and 8 inch in front? if so i found one of these in pretty good shape and bought it, but it has transmission problems. do you or anyone else know where i might find another transmission or repair parts? when i first saw this thing i thought it was something that someone had made.but it has a homesteader decal on the frame in front any info will be a big help. thanks,mike
Bret4207
05-04-2008 14:07:49
Link
That link should get you to the Brinley set up nstructions
Pete7
05-04-2008 05:32:48
Try the link below to this Cub Cadet site. Some of the folks at that site use their Cub Cadet garden tractors to plow. They even hold a "plow day". Lots of experience/knowledge about the Brinley plows.
Rusty Wheel
05-03-2008 21:18:48
I had the same problem with a Farmall Cub plow. It would only suck in about 3". I discovered the plow point was worn to the point it was riding on the heel of the cutting edge thus preventing the plow from going any deeper. I used a disc grinder to grind off the heel of the plow share and it does a fine job now. rw
M Moline Fan
05-03-2008 02:16:21
My guess is you'll have to add weight to the plow (and then probably to the tractor too). I have a Brinley plow I use with an old Bolens and I usually have to put weight on it. My dad has a Ford 2-14" he used to plow with on a Ferg. 30. He had 2 heavy weights bolted on it to get it to work in hard ground. You're plowing sod that hasn't been plowed in a long time. If you get the plow down 7" that kind of condition will be a challenge for a garden tractor.
Ralph - Ohio
05-02-2008 18:49:19
You said:
"It will go down just so far and then the plow kick down in front and up in back with just front few inches (4 or 5") of the plow digging a trench in the ground."
I don't know anything about your setup but it sounds as if the mounting is too loose if the plow is able to tilt forward as you described.
