Tool Talk Discussion Forum
Two metal working questions
Whitey2
05-02-2008 13:43:39
When cuttin with a torch how can you make a line that can be seen while cutting. I have scribed with some success, while the white metal chalk is worthless. Last time I used a angle grinder and with a cutting blade and followed the chalk mark to make the mark deeper and visible while cutting ..another question is where do you find a square hand held punch to make a round hole square so as the carriage bolt will fit the square under the round head. Last time I used the tail of a file, not what I would say the best but got the hole square.
T_Bone
05-04-2008 19:49:36
 Re: Two metal working questions in reply to Whitey2, 05-02-2008 13:43:39
Hi whitey,
Better late than never they say. For a square hole, drill a hole the size of the round bolt then heat the area cherry red then drive a square bushing driver into the hole. You"ll need to make sure you have a solid anvil backing up the metal that gets the square hole to keep from dimpling the metal as you drive it thru.
Here is a reprint of one of my past torch articles.
UpDated 03/26/05:
A trick I use for accurate free hand cutting is using a sanding disc to knock off the heavy scale and then use a scratch awl for my lines. The line is very thin so it makes following lines very easy.
Another is to stop cutting when you feel your hands or torch get out of balance. When that happens, stop and reposition the torch then continue cutting.
The cleanest cut comes from a clean tip. After you clean all the orifice bores in the tip, fire up the torch and set flame for cutting, then depress the cutting lever and observe the flame.
There should be a long very "uniform" inner flame cutting cone. If that inner cone is not "very" uniform then your cut will be ragged just like the flame cone is and the back of the metal will have slag. Reclean the center orifice until it"s very uniform.
A cut with a clean tip will have a very smooth cut surface with very little (if any) slag on the backside of the cut. If either one of these is not present reclean the tip.
The center bore orifice can get deformed and the tip needs replaced or cut off. It"s really important to hold the cleaning file straight in the bore hole and just removing enough material to clean the bore to make the tip last a long time.
I"ve never used a new tip that was clean enough for cutting right out of the box.
To expand on my thoughts:
Altough theres many different tip sizes, I have a found a No3 makes for a all around good cutting tip as it will cut upto 1-1/2" or 18ga sheet metal depending on the preheat setting.
Another consideration is as the tip size becomes smaller so does the orifice size and it becomes a bare to clean them ity bity holes. If using an automatic cutting machine then changing tip size would be a production benefit.
Setting the proper neutral preheat flame, the orifice holes around the center cutting orifice, can be observed by the tip of the inner flame cone. A neutral flame has a blue colored flame outer sheild with a light blue to white inner cone flame that is slightly rounded at the cone tip. A oxidizing flame (too much oxygen) has a sharp pointed very white inner cone. A reducing flame (not enough oxygen) would have a very round to a ragged thrid inner cone.
I have found 5psi acetylene and 30psi Oxygen while cutting to be a good all around setting for upto 50ft of 1/4" hose. Your final pressure setting is regulated by the needle valve adjustments on the mixing body.
For brazing or welding a size #0 tip works well with 5psi Acetylene and 20psi Oxygen. Again the needle valves on the mixing body sets the final pressure needed at the tip.
I also use the above settings to preheat 2" round bar without any problems using the #0 size tip or the rose bud tip.
The advantage to using a rose bud tip is that it expands the flame temperature over a wider area vs using a #0 size tip. I very seldom use my rose bud tip. Preheating with LP saves some expensive gas then finish heating with Qxy/Acet.
Never run Acetylene above 15psi for any reason!
I strongly urge you too research more information for your safety. T_Bone
Tony S.
05-04-2008 19:22:47
trick is heat the metal up a little, then wire brush the surface, you won't be able to get the soapstone off.
john niolon
05-03-2008 05:28:57
"Sharpie" marking pens that you can buy at Walmart have one in Silver that is easy to see under torch or plasma light... felt tip and they come with a tip that comes to a pretty fine point (1/16" or so) and also in a very fine but it doesn't hold up to marking steel... cost a buck or two but worth it. Now keeping it out of the grandkids hands...well that's different
john
mj
05-03-2008 04:06:31
 Re: Two metal working questions in reply to Goose, 05-02-2008 13:43:39
For really precise freehand cuts I scribe the line and then center punch along it every 3/8 of an inch or so.
trucker40
05-02-2008 19:37:36
I dont have the best eyesight,have diabetes,welded for many years,hardly ever use goggles running a torch.I just clamp a piece of flat metal where i want to cut a straight line.I can see the soapstone mark on metal.Maybe if you use cutting goggles maybe you have too dark a lens.It seasier to see with your goggles or hood if you have glass cover lens in them instead of plastic.Glass breaks easier and hot metal sticks to it,but not plastic.You can take your plastic cover lens out and wash it in soapy water helps too.There is a type of chisel I think that makes a square hole out of a round hole.I might have seen that chisel in a Enco catalog.There is a punch that you drill a round hole and then put this 2 piece square hole cutter on one side,run a bolt through the hole,put the other side of the cutter on the other side.as you tighten the bolt it pulls one side into the other and cuts a square hole.Dont know how small it goes.
Maark
05-02-2008 16:14:03
clamp a piece of angle or flat iron on your work to use as a straight edge for a nice cut. Just run the tip of your torch next to the edge.
Gerald J.
05-02-2008 13:59:51
Welders I know use soapstone to mark their lines and the lines survive.
As for punching, that would probably have to be done hot so the punch would be a blacksmith's tool. Otherwise a square file of an appropriate size cuts the round hole out to square. And than can be a lot of work in 1/4" steel.
Gerald J.
36 coupe
05-05-2008 04:23:24
 Re: Two metal working questions in reply to Gerald J., 05-02-2008 13:59:51
Square holes are made by a punch press.Most round holes are punched not drilled in steel under 1/2 inch.
jose bagge
05-02-2008 13:57:45
I use soapstone, or plain old blackboard chalk- and I see it just fine even with my raggedy eyes.
In sheet metal, I've always just let carriage bolts pull their own shoulders, but I do have a set of Greenley punches that pull rectangular swith holes through sheetmetal- they probably make square punches as well. Google up Greenley Metalworking.
