Tool Talk Discussion Forum
Wiring Electric Motors
Glenn F.
05-02-2008 09:53:32
Age is a cruel thing. For years my uncle has been the go-to man for so many things. Just one of the many is, wiring electric motors. He was able to wire 110/220, forward/reverse, etc. even if all diagrams were missing. Somehow he'd figure it out. The last year or two has not been kind to him. The time has come for me to learn how to wire motors. Can you folks give me some of the basics, like wire colors, combinations, etc.? Are there some generic diagrams which would apply to most motors? I have done a fair bit of electrical wiring, but have done almost nothing with wiring electric motors from scratch.
Thank you,
Glenn F.
dr sportster
05-02-2008 14:48:13
 Re: Wiring Electric Motors in reply to Glenn F., 05-02-2008 09:53:32
I had a good freind whos father was a GE motor distributor.The guy grew up around motors.He was the best motor guy and could answer any question or do anything with a motor.Last year he came home from bicycle riding and when his wife called him for dinner he had died of a massive heart attack[age 54].It was a major loss to everyone including all local electricians that knew him and that he gave info to.Since then Ive had some luck with google searching for info on a particular brand.The only problem seems to be when one manufacturer got bought out by another.Thats when info gets scarce.I still have two three speed motors I wanted to ask my freind about.Plus he had every hot rod type car magazine from 1959 to 2007.I miss that guy.
JMS/.MN
05-02-2008 13:24:41
Most single phase motors reverse direction by interchanging #5 and #8, with the other leads that they are connected to. Small, fractional hp motors do not ID those leads. But common on 1-3-5, 7 !/2hp, etc.
jwhart
05-02-2008 13:16:22
Also most motors come with a diagram on the back side of the cover plate on the wiring box or "peckerhead". To swithch rotation you just swith the leads. Most of the 2hp ac motors I have installed just have a ground and two wires. Colors usually vary. I'm not sure your type of motor or application but as others have suggested usually Google is a great friend.
buickanddeere
05-02-2008 13:09:55
Each 120V portion of the main windings have relatively low resistance to the one high resistance start winding.
John T
05-02-2008 12:33:24
Its likely possible to use an ohm meter to "ohm out" all the windings then perhaps figure it all out Im assuming its a split phase 120/240 volt single phase motor correct??
There should be two main motor windings with fairly high ohms that are the same in value and they are connected in series for 240 volts but parallel for 120
There should be a smaller ohms start winding and to reverse direction you swap its ends in reference to the main (series or paralell) winding. The start winding wires through a centrifugal switch if its a split phase motor like Ima thinkin it is, NO WARRANTY.
I like the idea better to Google out NEMA or Electric Motor Wiring codes or diagrams or standards etc as posted
John T
John T
Red Dave
05-02-2008 11:52:42
Last year I wanted to reverse an electric motor, but had no wiring diagram. I entered the nameplate data (manufacturer & size)into Google and it gave me a link to the wiring diagram for that motor. Suprised me too.
Worked good for me.
