Tool Talk Discussion Forum
OT.. 98 cavalier oil pressure check
bill b va
05-02-2008 07:40:42
i have 98 2.2 cavalier and the oil pressure light came on yesterday . don't know when it came on . noticed while driving . checked oil. oil ok . on restart light went off on engine start . today light goes off on restart . my question is there easy place to connect a pressure gage to check pressure . looks near impossible to connect a gage to oil pressure sensor port . thanks bill
Amarillo Doug
05-02-2008 10:54:06
 Re: OT.. 98 cavalier oil pressure check in reply to bill b va, 05-02-2008 07:40:42
My wife drives a 2000 Cavalier with the 2.2.Last summer the oil pressure light came on and engine was shut down as soon as it came on.Checked oil and was not even showing on stick,started to look for leaks and found the sending unit for the light had blown apart,dumped the oil.Didn't take long since it is only a 4 quart system.Checked pressure and replaced sender and have not had any more trouble.Could find no other place to tap into oil galley to check pressure.It is toght but it can be done.
bradk
05-02-2008 10:00:29
Serviced from underneath vehicle.
RobMD
05-02-2008 09:13:31
There's no oil pressure gauge in the cockpit? Hmm, if not, you can always just get a new pressure sending unit.
These sending units go out on Jeep Cherokees all the time, so maybe yours is bad... try this first before you keep running the thing around. I figure if you have a relatively safe amount of miles and you've been changing the oil, you should have some good pressure.
ORRR... there's always the chance that your pressure is still there but just low enough to turn the light on at times... high mileage vehicle.
Change the sensor first and see what happens.
bill b va
05-02-2008 09:58:36
 Re: OT.. 98 cavalier oil pressure check in reply to RobMD, 05-02-2008 09:13:31
i know what to do but theres too little room between the fire wall and the engine to replace the unit or connect a pressure gage . i am hopeing someone will know of another location to check the oil pressure .
