Gasket leak
Doc
09-12-2001 10:54:30
I have been confronted with a MAJOR problem ... for me, maybe not for some of you. My Ford 9N has a rapid transmission/hydraulic leak at the joint between the engine block and the transmission. I am unsure how to handle this. Do I unbolt the middle of my tractor, and hopefully nothing disengages or falls out, or do I take it out to the pasture and shoot it humanely because it's too big a job. What tools, supplies, jacks, etc., etc. will I need. Reference sources like manuals, websites, etc. would be appreciated. I am located in the Colorado Springs, Colorado area. Thanks.
Richard C. Rose
09-12-2001 17:04:38
 Re: gasket leak in reply to Doc, 09-12-2001 10:54:30
Doc, if the leak is between the engine and transmission your problem is most likely to be the gearbox/pto input shafts oil seal leak.
The job is a simple clutche split in that nothing should fall apart when you seperate the two housings. Both halfs need to be securely supported and the front axle needs to be jammed.
A service manual would be a must to consult if you are not experienced in this proceedure.
Best of luck Dicko
