Tool Talk Discussion Forum
HF Pipe Benders
Glenn F.
04-30-2008 02:22:06
Anyone have a Harbor Freight pipe bender (#32888 or 38024)? I've been kinda' interested in them for a while, but know I wouldn't use one a lot. If you have one, what have you used it for? Are you happy with it?
Thank you,
Glenn F.
dangerdoc
05-01-2008 19:18:53
 Re: HF Pipe Benders in reply to Glenn F., 04-30-2008 02:22:06
I've had a hydrolic pipe bender for 5 years, I've never bend a pipe with it, but I've used it numerous times to unbend things. In fact that was the reason I bought it.
Glenn F.
04-30-2008 15:27:47
Thank you for each of your responses. Nothing like your first-hand experiences. I'll not be buying one.
Glenn F.
timcasbolt
04-30-2008 14:06:55
I"ve got one of those benders, hardly ever used. Unless you pack the tubing with sand, the bend is unacceptable. Knowing what I know now, I wouldn"t buy it again.
ispud
04-30-2008 07:57:49
Have their 16 ton 1/2 to 3 inch dia. for a least five years don't use it that much but have made a few things with it works good for me but a little slow. I have used it on some prety heavy soild steel with good results. Hard to beat at the price think when I got mine it was $ 169.00 dollars.
jose bagge
04-30-2008 04:23:46
Glenn, I have a real live mandrel bender that I use for building roll cages out of 1.75 .095 wall and 1 5/8 .125. It does a great job, but I went ahead and got the HF pipe bender to save some wear-and-tear on the aluminum mandrels for my good bender. It WILL bend tubing and pipe- but since it has no real mandrel it compresses it badly at the bend- definitely not pretty/strong enough for roll cage work. HOWEVER,
I do use it with some 1 5/8 sched. 40 to bend up bumpers which get hidden under plastic covers. I still don't like the way the bends look (the purist in me), but...
I have not tried it with smaller diameter stuff
Old Magnet
04-30-2008 08:12:30
 Re: HF Pipe Benders in reply to jose bagge, 04-30-2008 04:23:46
I have both the 2 inch and 3 inch HF units.
Limit is 2 inch on either one. The heavier jack is handy on the larger unit but forget about bending 2-1/2 and 3 in. pipe. Does a nice job of mangling the bends on the larger sizes.
Glenn F.
04-30-2008 09:53:39
 Re: HF Pipe Benders in reply to Old Magnet, 04-30-2008 08:12:30
I did not see a 3" model. I'll check again.
If I got one it would be for bending galvanized (water) and black pipe. I would use it in making braces, brackets, cow stall dividers, calf pen dividers, etc. I would likely also do a little exhaust work. It would not have to do a beautiful job, but the end result would have to be functional, strong, and hopefully look OK?
Jose doesn't sound too impressed.
Do you think it would be satisfactory for my purposes?
Thanks,
Glenn F.
jose bagge
04-30-2008 14:46:40
 Re: HF Pipe Benders in reply to Glenn F., 04-30-2008 09:53:39
Glenn, I do not think you'd find it satisfactory for exhaust...not sure about the other applications.
Ron in Nebr
04-30-2008 10:57:33
Friend of mine has one and says it works ok. Should do fine for most of what you want to use it for except maybe the exhaust work. Keep in mind that this is a pipe bender, not a tubing bender...they're different.
Like jose says, it probably WILL bend the tubing but it'll likely collapse the tubing a bit...not the best thing if you're wanting a good flowing exhaust system. Try it on a scrap peice of exhaust tubing first and see how it goes.. One old trick for bending tubing without it collapsing that might work in this application, is before bending, cap one end of the tubing and fill it tightly with salt or sand, then weld a cap on the other end too. That way you can bend it and the sand will keep the walls from collapsing. After bending, of course, just cut the caps off.
