Tool Talk Discussion Forum
Impact wrench
Lanse
04-29-2008 17:47:30
I got a new 1/2 inch by 50' air hose at a garage sale for $10, and so i got it home and tried to remove the little 1/4 attatchment point from my impact wrench and it came out real easy, but now the trigger dont work. The thing i removed is a little blackk peice so that you can screw in a 1/2 hose instead of a 1/4. So now the trigger on the gun dont work. It is stuck wide open with all the air running out the exhaust ports without the chuck turning at all. So what did i do???
Towman
04-29-2008 18:03:49
 Re: Impact wrench in reply to Lanse, 04-29-2008 17:47:30
That part you removed isn't a pipe adapter. It is the trigger switch valve. When you took it off did a short stem also fall out. You need to put those parts back in.
Towman
Lanse
04-29-2008 18:18:54
 Re: Impact wrench in reply to Towman, 04-29-2008 18:03:49
there was one spring, but i think that woulda done it
