Tool Talk Discussion Forum
Z bars
Slowpoke
04-28-2008 01:28:41
That's the kind that's used between two sheets of 4x8 plywood siding when a top sheet is placed above the bottom sheet where the wall for example, is 16' high. The question is does the top sheet rest on the metal Z bar or is a gap, say 1/8" or so left between the bottom edge of the top sheet and the Z bar? I have to use Z bar because my siding is above a stucco wall which varies in thickness and level.
Thanks
RegoR
04-29-2008 06:23:45
 Re: Z bars in reply to Daniel Henebry, 04-28-2008 01:28:41
Slowpoke,
Sounds like you thought the project through pretty well.
I think the only thing I would add would be to rattle can the Z-bar surfaces that will contact the masonry with a zinc/galvanizing coating, hoping that that might extend the life of the thin metal. Or for that matter, I wonder how backer rod (or similar) set under the Z-bar would work to isolate the metal-to-masonry contact? That is, if you even share my concern in that regard.
I agree with the other poster(s) re: caulking the top edge of the stucco.
Roger
reply
04-28-2008 15:02:29
 Re: Z bars in reply to Slowpoke, 04-28-2008 01:28:41
Being in the siding business for over 30 years , I've seen it both ways. However,leaving it up 1/8th wouldn't hurt a thing. If I were installing it,I'd probably leave it up 1/8th,mostly for expansion and contraction. Most all my work has been asbestos,aluminum,and vinyl.
Slowpoke
04-28-2008 16:41:46
 Re: Z bars in reply to reply, 04-28-2008 15:02:29
To reply: the peak of the gable is 32" above the stucco. The pitch is 3/12.
bc
04-28-2008 13:54:23
I would raise it an 1/8" or 1/4" so it will drip and water won't sit on the metal and rot the bottom of your siding. It can also sit and eventually rust the z bar. Caulk all along the top and front edge of the stucco so no water can blow up underneath the z bar during a thunderstorm. I would also flash it going up at least 6". The z bar doesn't flash up very high. You could add a strip of 6" metal flashing that comes on a roll or better yet at Lowest and Home cheapo they sell this rubber roof flashing with a sticky back to it in a roll that comes in 6". Install the z bar and then flash above it before putting on your siding. It is more money but I also use the rubber roof flashing (which I think is better than tin) behind vertical siding seams for added protection on those seams. Some siding panels (such as hardipanel cement board) just butt together with no protection except for caulk and we all know caulk never lasts all that long. All of this will go onto the Tyvek (to help keep out the wind and moisture penetration) that I would recommend you use on any siding surface. All the extra flashing and protection will just add to your peace of mind. Like one of the others said, run a bead of caulk behind the bottom edge of your siding on the z bar to keep rain from being blown up under it during a T-storm.
Sean Feeney
04-28-2008 12:47:56
Had to Google Z-bar We all ways called it drip edge window flashing and we used it between sheets of T-111 as well, made of aluminum
RegoR
04-28-2008 12:26:35
Hi Slowpoke;
If I understand you correctly, you're considering placing Z-bar across the top edge of a stucco wall and using T1-11 above that.
I believe Z-bars are intended for wood-to-wood butt joints. I'd be concerned that the moisture content in the stucco will rust out the thin metal, unless you can find actual hot-dipped galvanized stuff.
Metal stucco grounds (I think that's the term) that are typicallly used at the lower-most edge nearest the foundation, are designed with holes and weeping ability.
Also, T1-11 is 5/8" thick and the Z-bar is made to fit that. How will the lower leg of the Z-bar lay against the rough, uneven face of the stucco?
Let us know what you come up with.
Best Regards,
Roger
Slowpoke
04-28-2008 17:18:47
 Re: Z bars in reply to RegoR, 04-28-2008 12:26:35
Roger: The stucco thickness varies between 3/4" and 1" so I used an angle grinder with a 4�" masonary disk along the edge to bring it down closer to 3/4". I had to furr out from the OSB sheathing using 1/4" plywood sheets so when adding the 5/8" T-ll it comes out slightly over the edge of the stucco in most places. The stucco extends to the ground level footing which is below the blacktop that surrounds the structure. Which makes an excellent highway for termites. Most stucco on older buildings in this area extends below ground level. I can't understand why the code allowed that...
Slowpoke
Slowpoke
04-28-2008 11:55:00
The building WAS a flat roof open carport. The original pitch was less than 3/8"/foot. Sides and back wall is stucco. I removed the 2x10 "pool walls", gravel, built up roofing material and 3/8 plywood deck, leaving the rafters @ 24" OC. On the rafters I built trusses and covered with 1/2" sheathing. The gable end wall is covered with OSB and Jumbo-Tex paper over which I am putting the T-11 with 8"OC groves. I need a Z bar between the top edge of the stucco and the T-11 because the stucco is uneven.
Christopher S.
04-28-2008 07:44:08
I would hold it up an 1/8" like you said. Ideally it should also not rest on the lower sheet, but be held up slightly as well. If you hold it tight, moisture will wick up through the bottom edge. Leaving the gap will allow a small amount of air circulation to prevent the wicking affect. Also if you have ever read the stamp on the back of OSB or similar products it recommends not butting the sheets tight. But leaving a gap to compensate for expansion and contraction. The movement of sheet goods is small but it still could be enough to push slightly on window openings, soffit, and the such.
greg b
04-28-2008 08:05:25
 Re: Z bars in reply to Christopher S., 04-28-2008 07:44:08
T1-11 plywood siding is not the same as osb, osb is used on roofs and wall sheathing
greg b
04-28-2008 07:11:46
I put it tight and also put silicon sealer behind the plywood siding good luck with your project
