Tool Talk Discussion Forum
Welding Rod
Jerry L /AZ
04-27-2008 06:57:24
Awhile back there was a post on Hard face rods. I can't seem to find it. and I was asked to build up the cutting edge on a bucket and can't remember the kind and type of rod to use. thanks for your help Jer
dlplost
04-27-2008 21:05:33
 Re: Welding Rod in reply to Jerry L /AZ, 04-27-2008 06:57:24
Here's a .pdf from Lincoln Electric on hard surfacing..
Jerry L /AZ
04-28-2008 06:08:16
 Re: Welding Rod in reply to dlplost, 04-27-2008 21:05:33
dlplost; Great stuff thanks Jer
pro welder
04-27-2008 20:05:58
This is a hard question to answer without knowing all the details, like how big a bucket, what type of equipment do you have, and just how much does it need to be built up. I have done cutting edges on buckets ranging from skidsteers to the spade buckets on cat mining loaders. If the cutting edge is wore to bad it maybe easier to replace it. I could make a better recomondation on what to use to build it up if I knew what you have for equiptment. I use 7018 stick or a flux core 71 mig wire that requires a sheilding gas. Then use hard facing rod on the final pass I personally like Unitec h60 because of its ability to go on in multiple positions.
Jerry L /AZ
04-28-2008 06:23:21
 Re: Welding Rod in reply to pro welder, 04-27-2008 20:05:58
Well to answer your question Pro It is two buckets 1'& 2' for a mini excavator. used in rocky,sandy gravel type of ground. real soft metal lot of mushrooming ,heavey dings. rippers and teeth don't last long. not my equipment just trying to help the guy. told him he can get hardened rippers and teeth but he does not want to buy them. Oh Well Jer
pro welder
04-29-2008 10:57:36
 Re: Welding Rod in reply to Jerry L /AZ, 04-28-2008 06:23:21
In that case build the cutting edge up first with 7018 then use hardfacing rod for your last pass or two, however do not put more then two passes of hardfacing on. I can't find any info on the Unitec H 60 rod but based on what I have read the Lincoln wearsheild 60 seems to be the same rod. I would recomend this for hardfacing your buckets because it has the best characteristics for a hardfacing rod used for digging in stone. Same properties as the rod I used for build up of the equipment in the quarries I used to work in. Here is a link to the rod.
Jerry L /AZ
04-27-2008 17:25:43
Thanks Guys for the information I printed it out and put it in my welding book won't lose it this time. T-Bone I'll do some more reserch on those lincoln rods thanks a bunch Jer
Hardfacing ?
04-27-2008 10:10:04
Are you building it up or are you trying to keep it from wearing out as fast? For welding a high carbon cutting edge on, 7018 is a good choice because it is a stronger rod. If you want to build it back up to size you could use 7018 but it will be softer and wear out faster. You can buy build up rods that are harder and don't mushroom but aren't a full hardfacing rod. They can be used for multiple layers to build things up. They are commonly used prior to hardfacing. Hardfacing rods are usually limited to 2 layers. Most buckets that are hardfaced just have one layer so it doesn't spall. (break off) There are different patterns that are used for hardfacing depending on what type of material you're working in. Go to the Lincoln or Stoody web sites and you will get some more info. There are many different types of hardfacing so a good welding supply could help you choose. Typical things to consider are abrasion, impact, corrosion, heat, metal to metal wear etc. when choosing hardfacing rods. Be sitting down when you get some of the prices though.
Ryan A
04-27-2008 08:28:50
a 7018,11018 or 7024 are good choices if you are using a DC current welder. if you have an AC current welder you may want to consider a 6013. i would recomend a 1/8 size rod for build up applications. the 7024 "drag and brag rod" with a DC current welder is going to be the easiest, but keep in mind this rod can only be used in the flat or horizontal position which will work in this application.
T_Bone
04-27-2008 08:26:35
Hi Jerry,
You can use 7018 or E70s to build up a base for adding hardface electrodes. Besure to check your hardsurface electrode mfg recomendations for the correct base metal prep.
What this base metal build up does is absorb the shock that the hardfacing gets thus it will last longer without fracturing.
Hardfacing electordes is not "one size fits all" applications and is why I say to check mfg recomendations on those electrode types.
Lincoln mfg's some fine electrodes so you might want to start there.
T_Bone
old
04-27-2008 08:20:44
I had some of it a few years back but don't remember the rod number. But any good welding supply place should have the stuff you want if you ask them for it and explain what you plan to do with it
rader
04-27-2008 08:11:39
A 7018 is a low hydrogen rod. Use it in places were you need ductility (flex).Its not hardfacing.
Ken Crisman
04-27-2008 07:16:54
Isn't 7018 DC a hardfacing rod ? I'm no welder by trade but seems to me that's what someone told me to use on my bucket & snowplow blades edges . God bless, Ken
