Hot riveting- has anyone done it recently?
GPWT
09-10-2001 14:55:20
As part of a tractor restoration, I need to hot rivet a grey iron air stack casting to a 16 gage air filter "can". The casting has a curved flanged mating surface and both parts have mating holes for 1/4" round head rivets. Does anyone have any advise about doing this? Due to the shape of the parts, I may have to put the rivets in cold, then quickly heat them with oxy-acetylene before riveting over. Any thoughts on this? I want to do this as close as possible to original.
Big Jake
09-11-2001 06:11:23
 Re: Hot riveting- has anyone done it recently? in reply to GPWT, 09-10-2001 14:55:20
I'd use Aluminum rivets & drive them with a bucking bar. The Al will move & fill the hole. You can pick up used bucking bars cheap at surplus yards
wrenchman
09-10-2001 23:47:16
i would use short carrige bolts & put the nuts on the inside where they can't be seen.use loctite red stud & bearing mount & nuts won't backoff.grey iron castings are easily broken & sometimes hard to replace.most factory rivited parts were done with presses to avoid this problem.just my opinion.
Franz
09-10-2001 21:56:20
The whole idea behind hot riveting is for the shrinking rivet, as it cools, to further tighten the assembly.
Heating the rivet in place probably wouldn't make enough difference to be worth while. You'd be better off bolting, and replacing the bolts one at a time with hot rivets. I don't know your specific application, but a small air hammer with a flat punch does wonders on small rivets.
