Tool Talk Discussion Forum
Bathroom Fan Vent...Cold Climate
Glenn F.
04-26-2008 21:20:37
A friend and I are going to install a fan in my upstairs bathroom/shower tomorrow. He recommends venting (using 4" insulated hose over a distance of about 12') it out the side gable as it's pretty hard getting to the soffit with a 4/12 pitch roof and 18" of insulation. He says he has done it successfully in the past. The wall which will have the vent faces northwest, the direction of our prevailing winter winds. My concern is: Even though we are quite well protected by woods on all sides, won't the vinyl shutter freeze shut at times?
As always, I appreciate your responses.
Glenn F.
T_Bone
04-27-2008 08:53:59
 Re: Bathroom Fan Vent...Cold Climate in reply to Glenn F., 04-26-2008 21:20:37
Hi Glenn,
Vents by code are required to be rigid duct.
This is too keep exhaust gas form collecting in a low section of the vent duct that would happen if using flexable duct.
By using rigid pipe you are creating a natural exhaust flow weather the fan is on or not. This can not happen if using flex duct.
12ft is a very long run for a bathroom vent and will exceed the static pressure (resistance to air flow) of the fan rating. Be sure this is with-in the mfg spec rating for your vent.
90� EL's are not allowed on vents and 45� EL's or less work the best. You can use the 90�"L" to make a 45� by adjusting each of the gores(segments).
Bathrooms are required to be a negitive pressure design to keep unwanted gases contained only to that room.
T_Bone
Bob - MI
04-27-2008 07:51:55
You can bury the hose in the insulation if you want to shorten the run and go through the soffit. If you choose this route put in a dedicated vent in the soffit and duct it outside. Do not just dump it in the soffit and expect it to be trouble free.
If you go through the wall you can use PVC to keep the inner wall smooth and stop condensate build up. I would pitch it toward the outlet a bit and insulate the pipe along it's length.
I put my fans on timers and always run them for about 10 minutes after I step out of the shower. This allows them to pull more moisture out and it keeps the condensate moving out the vents.
Timers are also handy if you find foul odors in the bathroom. Crank it to 5~10 minutes and walk away. All will be well and you don't have to go back and turn it off manually.
Mark-IA
04-27-2008 07:22:54
Are you close to the vent pipe? If so, just tie into that, or put it through the roof.
MarkB_MI
04-27-2008 08:10:20
 Re: Bathroom Fan Vent...Cold Climate in reply to Mark-IA, 04-27-2008 07:22:54
Tying a bathroom exhaust to the vent stack sounds like a good way to get nasty fumes into the bathroom.
Vern-MI
04-27-2008 04:27:21
I did almost the same thing but the run was shorter at about 9 feet. I used the expanding 4 inch vent tubing so that there weren't any seams that could leak condensate into the attic. It has been there several years and works fine. It gets below zero here and it still works OK.
MarkB_MI
04-27-2008 04:18:38
You can get a vent kit that goes in the roof, Home Depot sells them. I put one in our upstairs bathroom last year and had no problems all winter even though we had a lot of snow.
