Tool Talk Discussion Forum
Welding Positions
Sam from WA
04-26-2008 21:14:18
I gotta jog my memory here: The neighbor kid came over this afternoon to see if he could have me help him with deciphering some welding postion codes. I do a lot of welding at work, but I don't use a blueprint with the welding symbols on it. So, for the question: Weld postions 2F Horizontal, 3F Vertical, 4F Overhead, and 1G Flat: what does the number and letter combination signify? I don't think I have ever known what the codes mean, so any answers are great, and I will pass them onto the neighbor.
T_Bone
04-27-2008 08:03:10
 Re: Welding Positions in reply to Sam from WA, 04-26-2008 21:14:18
Hi Sam,
I just updated my electrode chart that been posted in the archives:
UpDated: 04/26/08
First two digits= tensile strength in psi
(60)11= 60,000psi, (70)14= 70,000psi, etc
3rd digit= position, 60(1)1, 70(1)4, etc;
1=all position,
2=flat, horizontal,
3=flat
4th digit= electrode covering (I covered this about a week ago in another thread) 601(1), 701(4)
As far as my personal prefference of the choices listed for any other position than flat:
7018
6010
7014
6011
6013
That always doens't hold true as it depends on what I'm welding, metal type, joint type, joint access, etc. Also depends on what electrode brand. Lincoln 6013, I like AC or DCEN.
If in doubt, use 6011 first.
Galvanized only 6011 or 6010 with DCEN
If you need new rod, then consider buying Chemtron 7018 and Lincoln 6010. With these two rods, I cover all my mild steel welding needs.
It's the electrode flux that first determines the best choice of welding current type. Since flux composistion is classified "top seceret" by the manufactures we can only generalize without looking up the mfg electrode recomendations.
If your using a unkown electrode mfg then you can use this "generalized" list:
Last number on the rod is flux type:
8= DCEP
O= DCEP
1= DCEN
2,3,4 or 7= AC or DC
5= DCEP (only)
6= DCRP, AC, DCEN
DCEP= DC electrode positive also called reverse polarity
DCEN= DC electrode negitive also called straight polarity
This list doesn't hold true for all electrodes brands. If the above list recomends DCEP and the electrode doesn't run well, try DCEN, then AC.
Types of Weldments:
F= Fillet weld, as in a "T" weldment
G= Grove weld, total open bevel 33�
J= 1/2 of a grove weld or bevel on one side (k)= is a specical restriction character
1F= flat fillet
2F= horizontal fillet
3F= vertical fillet
4F= overhead fillet
1G= flat groove
2G= horizontal groove
3G= vertical groove
4G= overhead groove
5G= fixed 90� pipe welding from the bottom to the top
6G= fixed 45� pipe welding from the bottom to the top
6Gk= fixed 45� pipe with a restrictor plate located 1" from the weld toe, welding from the bottom to the top.
This above reffenerence will cover 99% of the weldments that you will run into.
T_Bone
Stan in Oly, WA
04-27-2008 09:42:16
 Re: Welding Positions in reply to T_Bone, 04-27-2008 08:03:10
Hi T_Bone,
Either you've got a lifetime supply of that Chemtron 7018 or your supplier does. I don't think it's been on the market for a long time now. I couldn't find any information about it online after first reading your high opinion of it on this forum, and that was the best part of 10 years ago.
The name Chemtron now seems to belong to an Ohio waste disposal company that seems to have their share of problems with the EPA.
Apparently ESAB bought out the Chemtron that produced electrodes but doesn't use the name any more. I read one reference to Chemtron and ESAB Atom Arc in the same sentence but haven't seen any information that they're the same thing. I'll kick myself if I discover that they are because I sold a large quantity of ESAB Atom Arc 7018 that I had come into possession of and had no use for.
All the best, Stan
guido
04-27-2008 07:05:22
Hello Sam form WA
From what I remember the letter F is for the type of finish for the weld, the number symbol does not ring a bell? It could be 2 passes?
What is the material to be welded and the size of the material?
Guido.
Tommy D6-8U
04-27-2008 06:53:27
Sam,
I've got a book or two here from my AutoCad and ME classes that have that in it if I can put my hands on them. will look today; kinda curious myself!
Dave_Id
04-27-2008 06:00:14
That's for the size trowell that is required to keep the gob of weld in place.. just kidding of course. I remember a movie in welding class where this cartoon character used a trowel to keep the weld in position, but of course it all fell to the floor when it cooled.
