Tool Talk Discussion Forum
Bissell Pro-Heat
Mark-IA
04-26-2008 17:42:29
We have a Bissell Pro-Heat carpet cleaner. The pump locked up. I replaced the pump assembly, but I can't get it to either suck water or deliver carpet cleaner. The pump shaft is turning. What to do?
WBinPA
04-26-2008 18:42:06
 Re: Bissell Pro-Heat in reply to Mark-IA, 04-26-2008 17:42:29
I tried to fix mine also without luck. FWIW.
LenND
04-26-2008 18:19:37
Could it possibly be air locked? Maybe you will have to prime it, just a suggestion.
Cas
04-26-2008 20:49:48
 Re: Bissell Pro-Heat in reply to LenND, 04-26-2008 18:19:37
I have a Bissell pro heat it wast used very little. I took it apart quite a job the first time. The problem was the heater. If your take
the plastic hose off and try blowing thru it might be your problem. I opened mine up with a
sized drill and it works
