Tool Talk Discussion Forum
WACKER STRING...IDEAS?
jose bagge
04-26-2008 08:22:41
Wy weed wacker RUNS great- but I go through 100 feet of string in no time! anyone had any luck with a particular brand- or something other than string?
Sam#3
04-26-2008 23:19:12
 Re: WACKER STRING...IDEAS? in reply to jose bagge, 04-26-2008 08:22:41
I have a spool of Stil that holds up pretty well as long as I keep it out of the chain link. I also have some that I bought from Wally. It breaks off at the mower head. I'm running a little Homelite that's about 7 years old. It starts and runs well on E10 gasahol/40-1.
Alex-41JDb
04-26-2008 18:16:27
Have tried everything, stay away from the diamond shaped and the saw cutting type stuff. Alex
guido
04-26-2008 15:34:25
Hello jose bagge
You did not say if you need to advance the line or if it breaks. The thing that makes the line last is a steady and fast enough speed to do the trimming. If you hit a small sapling and the string goes around and it breaks, the rpm's are to high. When you are running at the wright speed the line will not break. I use a ribbed commercial line for my trimmer. Make sure that you are not advancing the line also it will be trimmes at the line cutter, the line won't last long that way.
The best way I have found to trimm is with a steady speed, just like your car on cruse control. Revving the engine up and down is a sure line killer!
Guido.
Arkandan
04-26-2008 08:44:51
One of the posters recommended the teflon string from Lowes last year. I got some and it really works well. Last much longer than the el cheapo stuff. I was into TSC a few weeks later and noticed they had it too, but was a buck or so cheaper. It isn't really all that much more expensive than the cheapo stuff no matter which one you get it from. Much luck.
