Tool Talk Discussion Forum
Hearing aids
jack12345
04-24-2008 21:32:30
I know this may be pushing it a bit,but if you're working on a engine and you cannot hear tic tic etc or a micro switch trip and you can hear it with a little electronic circuit it must be a tool!
My questions is: with all marketing and cost which type of aid suits YOU best? With behind the ear models do they fall off when working around equip? Give me some of your expert user advise. Thanks, Jack
DiyDave
04-26-2008 15:58:33
 Re: Hearing aids in reply to jack12345, 04-24-2008 21:32:30
What?
RobMD
04-25-2008 20:55:53
I was born mostly deaf. I can say with absolute 100% certainty that no hearing aid will get you the precise, crisp hearing that normal ears do.
That's period. Being born mostly deaf, I know the most about it.
RayP(MI)
04-25-2008 15:35:29
One of my son's teachers had one that was externally adjusted by a remote control, like a TV remote. She could apparently adjust several things, not just the volume. Unfortunately kids found how to turn it down, and delighted in swiping control, and putting her out of communication!
Bob85355
04-25-2008 12:23:38
I"m 70 years young and have have worn hearing aids since 1983, that"s about 25 years. I"ve gone through 5 sets. Only one set wore out, the others became outdated due to new technology.
The digitals are really very good. What they do is break the sound into discrete parts and then reconstitute it to your particular need. That"s where the audiologist become important, determining your need. The second important thing is fit. If they are not comfortable, you won"t wear them. Again, that where the audiologist is important, the fitting.
I"ve had behind the ear and liked it but it would fall off. So, I switched to what is called a full shell.
If sounds get too loud for you when wearing your aid, have the compression adjusted. That limits the maximum that your aid will allow. Some audiologists will tell you it can"t be done. Wool shirt, it can be and I"ve had it done.
You"ll also be told that the new hearing aids will mitigate recurrent sound such as tire noise on the road. Very true but if anything interrupts that sound pattern, all that road noise comes right back. What"s it mean. Can"t play your radio and hold down road noise.
Audiologists like to sell digitals that are set for your everyday living experiences. In other words, you can"t adjust them. Don"t buy into that. Been there and done that and don"t like it. My current set is what they call the senior citizen model. Each has a volume control. I can get into a noisy environment like in a resturant, reach up and cut the volume and enjoy the meal.
I"ve only had one aid repaired. The microphone went bad and it cost $75 to get it fixed. They sent it to the manufacturer and instead of a repair they duplicated it.
Bob
bobia
04-25-2008 10:14:10
I have had one for 17 years . works good except in wind. sometimes crownds make me shudder. I only wear mine at leisure times as don,t like it outside. Thing I noticed most was when I went to bathroom i heard the tinkle which I hadn,t before (grin) need one in other ear now . as far as repairs just clean them and last time I couldn,t get it to work all they did was clean. showed me where I hadn,t been
Jimdril
04-25-2008 09:36:32
I got a pair of Siemen hearing aids about a year ago, replacing another brand I'd had for about 10 years. They were rebuilt once for about 200 bucks. These new ones are digital and far and away superior to the old ones. I can actually hear the birds again! Best of all these were free through the VA.(Korean war vet), Well there was a $50 fee.Not too bad.
Eldon Yates
04-25-2008 07:28:55
The best hearing aid for troble shooting a motor is a the siphon hose.
One end to an ear and the other probed around listening around for the sound.
As far as hearing aids go. They are great at first but after you find out that they only last 6 months to a year before needing major repairs they lose a lot of the luster.
The biggest improvement to my hearing aid (siemens behind the ear simple digital series) was the day I bought a small hot rock. The kind of hot rock they use for lizards and snakes they sell at the pet store. It stays about 100-110 degrees and anytime the aid is not in my ear it's on the rock staying warm and drying out.
The hearing aid person frowns about using this method for keeping it dry, but it is THE ONLY WAY I have found to get any longevity out of a unit.
CNKS
04-25-2008 07:35:57
 Re: Hearing aids in reply to Eldon Yates, 04-25-2008 07:28:55
Sounds like you have a "wet ear" problem. People vary. Have had mine for almost 5 years, zero repairs, but that does not mean I like them. They help, but that's about all.
Eldon Yates
04-25-2008 07:47:02
 Re: Hearing aids in reply to CNKS, 04-25-2008 07:35:57
Last time it went in for a new ear mold to a different (Siemens recognized) hearing aid shop I sat and watched as the technician poked a needle right through the microphone section, look at me and say that it "needed to be sent out for a $200 repair."
Then they gave back me a different unit with a Siemens salvaged/surplus history and didn't even set it to my prescription.
I eventually was able to receive limited satisfaction, but not without bringing into play the state and it's licensing agency to persuade the crooks to fess up.
Beware.
I've been using aids quite a while and paying out of pocket the whole way. Over and over.
Ken 46
04-25-2008 06:46:16
I agree - the sound is not totally natural.
I have had my hearing aids about a month now- It wasn't hard to get used to wearing them - but the world is LOUD!!!! The screech of the front door-key tapping on the computer - I know I haven't heard those sounds for a long time -but they seem un-natural
Mine are the behind the ear - don't have any trouble with them coming loose or off.
I need them to hear conversations - but I don't like them
Ken 46
CNKS
04-25-2008 05:23:21
Hearing aids won't necessarily help you diagnose an engine. Had them since 2003, the sound is not natural, I really prefer not to use them listening to the engine. Sort of depends on how bad your hearing is. Mine is pretty bad. Currently have the medium size in the ear type. About 5 years old, have been turned up several times, now they whistle. My new behind the ear type should be here today. Perceived advantages are fitting in the ear is small and less noticeable as to how it feels. Can use a larger battery, thus enabling the aid to last longer due to more "headroom" as far as volume control. They apparantly hang by the tube that hangs on the ear and don't fall off. I will find out shortly I hope these last 10 years instead of 5, I don't know. Size of the aid is restricted by battery size, the larger the battery the larger the aid. All are digital so I doubt if there is much difference in performance. If you have not worn them before, they do NOT restore the original sound and bring out every loud sound you do not want to hear. The in the ear type require a clay type mold, very easy to get a bad fit which requires another mold, etc. The feel is not transparant, you will never forget about them.
I do not like hearing aids, but it is either being deaf or wearing them.
