Tool Talk Discussion Forum
Can't find serial number on Ford 2000. Need help!
Melanie Friend
04-24-2008 11:14:00
I can't find the serial number on a Ford 2000 3-cyl we recently purchased at an auction. We've been told to look on the transmission, but it is not there. We aren't sure of the year and need a manual. Can anyone help?
Charles Lee
05-13-2008 18:34:27
 Model number-Ford 3600 in reply to Melanie Friend, 04-24-2008 11:14:00
The model number is (CA213C)C is 3600,A I don't know.2 I don't know.1 is Diesel.3 is Live 540 PTO.C is 8-speed.Also ser # B992409,Made in Basildon,England.Production Code,1-30-1978 Day.Maybe someone knows more.
Thanks Charles
Charles (in GA)
04-24-2008 15:02:38
 Re: Can't find serial number on Ford 2000. Need help! in reply to Melanie Friend, 04-24-2008 11:14:00
Go to these web pages for the location and to decipher the date code and other codes.
Right side (where the s/n of the entire tractor is)
Link
Left side (where other info is found)
Link
It is on a horizontal flat, milled surface, usually a half round milled flat, behind the starter on the bellhousing, RH side.
I have a 1967 model 2000 3 cyl gas model.
Charles
Fordfarmer
04-24-2008 13:46:46
Unless it's been eaten by battery acid, the serial, model, and unit numbers are on the front edge of the transmission housing (bellhousing, clutch housing), just above and aft of the starter - right side on a '65 or newer Ford. There is, or was, a sticker with these and more numbers, under the right side of the hood. Open it as if you were going to check the battery, and it should be right above the battery.
JMS/.MN
04-24-2008 13:12:41
I have a 4500 Ford backhoe, probably a similar era- and the numbers are on the clutch housing casting where the rear of engine bolts to it- check on either side. Lots of number- build date is part of it.
