Tool Talk Discussion Forum
What kind of torch?
jwhart
04-23-2008 15:44:06
I"ve got a JD 1010 that im trying to remove the rear wheel. With no luck with a puller, i"ve been suggested to use a torch. I have a standard propane torch, but it"s not even getting the hub that warm. Im on a low budget on this project and need to know what might get it hot enough. Maybe the bernzomatic mapp high flame torch? I visited their website but theres no indication of temperature rating.
thanks
TomTex
04-24-2008 06:01:38
 Re: What kind of torch? in reply to jwhart, 04-23-2008 15:44:06
Oxygen & Acetylene rosebud. Couldnt get by withour my rosebud. Tom
ispud
04-23-2008 23:04:19
I would use propane, with a rosebud. Went to propane for heating & cutting years ago never regreted it.
buickanddeere
04-23-2008 16:45:01
Used to use a Benzo-Matic turbo torch. It came with about 4 ft of hose and could be attached to a 20lb BBQ tank with an adapter. I sometimes still use it for bulk heating large projects before using the oxy=acetylene.
jwhart
04-23-2008 16:17:26
What about a oxygen & Mapp kit like you get at Home Depot? Or would it still not get it hot enough as the acetylene?
TimV
04-23-2008 16:24:49
 Re: What kind of torch? in reply to jwhart, 04-23-2008 16:17:26
jwhart: if you've got any appreciable amount of mass to heat up, MAPP is not enough hotter than propane to do the job. A Turbo Torch setup (air/acetylene) will work, but the little propane and MAPP bottles just don't give you the flow you need to get a lot of metal warm.
JMS/.MN
04-23-2008 16:02:57
No way a propane torch will heat metal enough to loosen rusted on wheels, etc. Oxy/acet is the only one. Have a friend with one?
JMS/.MN
04-25-2008 08:27:02
 Re: What kind of torch? in reply to JMS/.MN, 04-23-2008 16:02:57
Oops- I thought you meant something like a Bernzomatic soldering propane torch.
Nebraska kirk
04-23-2008 16:02:03
Oxygen & Acetylene torch.
