Tool Talk Discussion Forum
ATF Acetone-Better than any penetrating fluid
PaulButler
04-23-2008 12:11:45
Anyone here heard of using a 50/50 mixture of acetone and ATF?
There were some discussions about it on NewAgTalk so I gave it a try. WOW! I have had some stuff laying around for a couple years because I couldn't get it apart-2 days with the occasional squirt of Acetone/ATF and I got it out without using heat or even a cheater bar.
Just wanted to pass along.
Paul
Butch(OH)
04-25-2008 18:49:25
 Re: ATF Acetone-Better than any penetrating fluid in reply to PaulButler, 04-23-2008 12:11:45
The active ingredients of all penetrating fluids are nothing more than oil plus solvent. Each Mfg has its own ratio and then adds color and perfume so its looks and smells special. For years we recycled the dirty stoddard solvent from the parts cleaner and used it as our own penetrating oil and it worked exactly the same as any store bought I have been around. Dad and I used to laugh that if we could make it look purdy and change the smell we could bottle it and be wealthy, LOL Try your dirty parts cleaner fluid and be amazed also.
Butch(OH)
04-25-2008 18:49:04
504-2
04-23-2008 19:06:50
I do not remember where I read it but a 50/50 mix worked better than anything else they tested. acetone/atf
Bus Driver
04-23-2008 16:53:59
I am confident that it will work well. But the acetone will evaporate rapidly. Keep your supply tightly closed. Liquid Wrench used to use similar solvents.
Gerald J.
04-23-2008 14:11:09
Home Shop Machinist compared that brew to the best of the comemrcial penetrating oils a few months ago. And it worked best for their test. They made up test samples and then ran them through days of salt spray to rust them equally. The ATF acetone mix turned the pieces with half the torque of the best which was Kroil.
Gerald J.
Bendee
04-26-2008 21:12:17
 Re: ATF Acetone-Better than any penetrating fluid in reply to Gerald J., 04-23-2008 14:11:09
See an advert for Nitrogen spray on for removing rusted nuts.Anyone heard of this??
