Tool Talk Discussion Forum
Windows painted shut
Stan in Oly, WA
04-22-2008 07:07:54
Any advice on unsticking the bottom section of double hung windows which have been painted shut for years? I've done it with other windows in other houses but it's been long enough ago that I don't remember any good tricks I learned, or any things to particularly avoid.
Thanks, Stan
Bud in WV
04-22-2008 16:09:50
 Re: Windows painted shut in reply to Stan in Oly, WA, 04-22-2008 07:07:54
All the info sounds like what I do. After it's loose, "lube" the wood/ metal tracks, etc with some paraffin wax . Kinda like lubing a wood screw with soap or bees wax....
Tom in TN
04-22-2008 10:03:43
Stan,
Glen has it just right. I've unstuck many old windows that way. One last thing, when he says to go around the window, he is including the seam between the bottom window and the top window. Be sure to get those separted also.
Good luck,
Tom in TN
glennster
04-22-2008 07:35:57
i go around the window with a stanley knife and cut thru the paint as best i can, then come back with a thin blade putty knife, gently tap the blade into the seam, work all the way aruond the paint line, get it in there a little bit then wiggle it to break the paint loose.
flying belgian
04-22-2008 08:22:56
 Re: Windows painted shut in reply to glennster, 04-22-2008 07:35:57
Yup. Thats about the only way.
rhouston
04-22-2008 07:51:55
Glennster has the same process I use. If you have to get some leverage under it I slip two putty knives under the window and stick a pry bar between them. This will keep the pry bar from marking up the window sash. NOTE do not pry too hard or you may break the window panes.
