Rpm
jerry
09-08-2001 03:16:14
i have a john deere model m 2cyl how do i set the rpm my tack and dwell is for 12 volts mine is 6 volts and 2 cyl
Bob M
09-09-2001 05:47:29
 Re: rpm in reply to jerry, 09-08-2001 03:16:14
Most 12 volts tach/dwell meters work fine on 6 volts.
For a two cylinder engine, set the tach/dwell to "4 cylinders", then double the meter readings to find the true 2 cyl RPM and dwell angle.
