Tool Talk Discussion Forum
Another golf battery question.
Robert in Md
04-15-2008 15:18:29
I put in one new battery last October and buickanddeere is right, the cart was better but not much better. Now I want to replace the rest of the batteries. Would I get good results with just replacing the five old batteries or do I need to bite the bullet and replace all 6 batteries.?
jdemaris
04-16-2008 05:41:44
 Re: Another golf battery question. in reply to Robert in Md, 04-15-2008 15:18:29
The main problem is the voltage of each battery - nominal and under load. They need to match - otherwise they constantly try to equalize and match each other. New batteries tend to have higher voltage than old.
Sometimes you can mix and match old and new batteries, or different brands - and do fine. Check the voltage of each one first.
rockyhawaii
04-15-2008 20:58:55
I had a battery that got broken, and I replaced the one battery with no ill effects.
JeremyR
04-15-2008 17:26:38
When we change out battries at work, we replace them all with a matched set, even if only one cell is bad. If the others in the set are still good we make a set matching date codes and voltages. Mixing new with old or uneven voltages will draw down the new. Jeremy
Kevin2
04-15-2008 16:57:31
I would go with the 5, a six month old battery shouldn't be a problem IMO.
