Tool Talk Discussion Forum
Welding Helmet...Lens Size?
Glenn F.
04-15-2008 12:55:40
I am casually looking for an auto-darkening welding helmet. I have not looked closely, but have noted there are at least two different sizes of lenses. The helmets with the larger lens are more expensive. Is the larger lens a significant advantage?
This would be no place to save a few bucks if the larger lens models are noticeably nicer.
Thank you,
Glenn F.
jose bagge
04-16-2008 17:14:32
 Re: Welding Helmet...Lens Size? in reply to Glenn F., 04-15-2008 12:55:40
go with the big lens...and the auto mask is defitely worth the purchase. You will be amazed at how much cleaner the start of your welds will become
JoeK(WI)
04-16-2008 07:33:29
Imho it kinda depends on the job.The advantage of the auto-darks is not having to constantly flip the helmet/lens up and down between welds.If your're mainly tacking up close etc,the small lens is fine.But the larger lens gives you a larger field of vision and a less"head in a bucket"feeling on longer/larger jobs.
Also for glasses wearers,you can get prescription inner lens holders for small lense helmets,don't know as I've seen em for large lens,though they're prolly available.
KEB1
04-15-2008 20:43:04
If you wear bifocals, definitely spend the extra money on the larger viewing area. I'm a pretty much amateur welder, but I've tried both, and with my bifocals there's a world of difference. I could never get the helmet positioned right to be able to look through the bifocal part of my glasses with the smaller viewing area. Its hard to weld when everything is fuzzy. With the larger lens, I can actually focus on what I'm doing.
I did try a set of magnifying lens in the helmet with the same power as the additional correction in the bifocal part of my glasses. Helped, but not nearly as much as being able to actually use my regular glasses.
If you use reading glasses, or don't need glasses at all, I suspect the larger lens wouldn't be worth the extra money. I was lucky, found a deal on a lincoln mig welder, and it came with a brand spanking new high end Hobart autodarkening helmet. Otherwise I'd probably still be struggling with the old smaller lens one.
Keith
Stan in Oly, WA
04-15-2008 14:25:03
Hi Glenn,
If there's no way you can get around having to wear bifocals while you're welding, then I think the larger viewing area can make a real difference. I'm borderline on needing reading glasses and generally don't wear any glasses other than protective ones while I'm welding. In a side by side comparison of welding helmets I conducted for my own edification last year, I got mixed up at one point and thought I was wearing the helmet with the big window when it was actually the other one. I remember specifically noting that the viewing area seemed pretty generous, so I was quite surprised to find that it was the smaller window I was looking through. To me that constituted a more objective finding than I can usually trust myself to make in that kind of situation. I never know how much to allow for the tendency to be favorably impressed by anything that supports the conclusion I would like to reach (i.e. cheap a/d helmets are just as good as expensive ones.)
All the best, Stan
mike bauer
04-15-2008 13:15:37
hey buddy how are you, the differance with the lens sizes is the bigger ones usually have more pick ups on them witch activate the auto darkening mechanism. when buying a A/D helmet I would go with the most pick ups you could find for the reason, when your welding in tight areas the more obstacles you have in your way the more of a chance of the mask not triggering due to blockage from the pick ups. I would also suggest to buy one that has no batteries, and is solar charged, they never go dead because of the U/V rays from welding.Hope that helped ya buddy.
