Tool Talk Discussion Forum
Shop Paint?
PJH
04-13-2008 11:55:01
Noticed the thread below about Kilz paint. I'm slowly sheeting my shop with OSB, and when I get done (if ever), I'd like to paint the walls and ceiling white. I've had several people recommend a Kilz-like primer to stop the yellow bleed that you get from the OSB. For the top coat, I get some recommendations for interior wall paint, and some recommend exterior house paint because the building is not constantly heated in the winter. What do you folks think?
big fred
04-14-2008 09:01:34
 Re: Shop Paint? in reply to PJH, 04-13-2008 11:55:01
I had good luck with a skim coat of drywall mud over the OSB, to smooth out the surface, then a PVA primer and a coat of latex paint. It ended up looking identical to the drywall that butts up against it.
El Toro
04-14-2008 07:10:15
I used Kilz primer on pressure treated plywood and then coated it with exterior latex paint. It was just installed and painted it last summer. Still looks good so far. Hal
RobMD
04-13-2008 19:13:24
exterior sealed and sanded OSB found ONLY in the cargo container industry holds paint excellently. perhaps you could seal it with the kilz stainblocker before it bleeds through. I think that may work well.
Ron Anderson
04-13-2008 14:13:07
I have done quite a bit of this and would suggest a oil base primer that would stop bleed through from bare wood followed by exterior latex Satin finish white. You don't want a high gloss white as it reflects too much brightness.
