Tool Talk Discussion Forum
Kiltz Paint
Mike(OK)
04-12-2008 09:13:43
Wondered if anyone knew anything about the Kiltz paint. Need to paint in an old farm house with about 40 years of an unvented gas heater and nicotine on the walls and ceilings. Have washed with mild detergent (dawn) and warm water. Does the Kiltz paint actually have a Kiltz base or would I still need to prime. Thanks for any help.
rhouston
04-14-2008 07:42:57
 Re: Kiltz Paint in reply to Mike(OK), 04-12-2008 09:13:43
I have used both their paint and primer. I have to agree about the latex version of the primer- It does not work anywhere near as well as the oil based Kilz primer.
I have also used the Zinzer primer mentioned below It works fine also.
I do like their paints but I always prime first.
El Toro
04-14-2008 07:13:22
I have used the Kilz primer over pressure treated plywood and then coated it with exterior latex. Still looks good. Hal
mark
04-14-2008 04:33:55
Kiltz?
You don't want that stuff..... it rolls on in a plaid pattern!
Gary from Muleshoe
04-13-2008 07:04:31
I have used it some, but I found that Do-It-Best stores have a primer that works just as good at half the price. In my opinion (which isn't worth a lot) you are just buying a brand name.
Billy NY
04-13-2008 06:46:19
I have used this product with excellent results, see the link below:
cps140
04-12-2008 18:30:39
Do not use kilz outside!!
Oil based inside, may need 2 coats if stain is bad.
sojono
04-12-2008 16:20:44
if you use kiltz use the kiltz original which is oil based if stain is really bad use pigmented shelliac which is alcohol base u can get both at any paint store.
rgvtx
04-12-2008 12:41:55
Mike,
Quite a few years ago I caught a car on fire in my garage. Although I got the fire out fairly quickly, the smoke damage was very heavy. The garage was finished with sheetrock that had not been taped or painted and was over 20 years old when this happened. I purchased a product from Zinsser and after just one quick roll on coat for the ceiling and walls it was ready to paint. I never realized how dark that garage was prior to the smoke damage that caused me to paint. I could almost work out there without lights after that. I think I bought the Zinsser at Home Depot and although it wasn't cheap it worked perfectly for me. A word of caution though, plenty of ventilation. The stuff really stinks. Oh, and be sure and have the proper stuff for clean up too. Plain old paint thinner wouldn't clean up the floor, seems like I had to use lacquer thinner which is another nasty odor.
The image below may not be what I used, as I recall it was a lacquer base instead of oil.
third party image
ErnieDD
04-12-2008 11:20:06
Use the shellac based Kilz primer, not the water based. Water based will look ok until it dries, then the stain will migrate through the paint. After the 6th coat it was still happening and then used the solvent based primer.
greenmisterg
04-12-2008 09:36:11
I'd prime it first!! Ii think they make a primer to cover old construction so I'd check it out...Try their web site? Google iy...
Spook
04-12-2008 10:18:18
 Re: Kiltz Paint in reply to greenmisterg, 04-12-2008 09:36:11
I have used their primer, works good.
Spook
04-12-2008 10:18:09
Spook
04-12-2008 10:18:03
M Moline Fan
04-12-2008 10:49:25
 Re: Kiltz Paint in reply to Spook, 04-12-2008 10:18:03
I think they have a product that's suppose to be a combination primer and paint. That might be worth asking about at the store to save some work?
