Dry Box For Welding Rod?
MO
09-04-2001 11:58:36
Can anybody share their ideas for a dry box to keep their welding rods warm and dry? Would a box made of plywood work? Do I need a light bulb to keep things dry? Any help is welcomed. Thanks,
MO
BlueLite
09-05-2001 14:49:42
 Re: Dry Box For Welding Rod? in reply to MO, 09-04-2001 11:58:36
Get a good size length of 4in black abs pipe
used for plumbing. Get a male screw cap for it. A threaded female flange piece for the screw cap that glues to the 4in pipe, a cap end. ABS pipe glue. Glue a circular piece of inner tube to the bottom of the end cap to act as a bumper for the rods when you slide them in. Make as many as you want.
Try to get the rubber seals that fit under the screw cap edge otherwise you'll have to screw it to the end to get a tight moisture seal.
cannonball
09-05-2001 04:24:28
i use an old up right freezer with metal inside with light buld on theromstat set about 110..keep roods real good and is big enough to keep lots of rods..keep grinding disc s there also....later
Redtractorman
09-04-2001 18:18:41
I use an old MicroWave oven
Alvin NE WI
09-04-2001 18:00:00
I got a small apartment size electric stove that quit working,put a couple racks in it and wired up the bulb socket that was in it to a cord and plug it in. Doesnt have to be a very big bulb to keep things dry and warm including low hydrogen rods.Every thing else is cut off. worked for me many years
S bogusta
09-04-2001 17:00:19
Mo, I used an old small refrigerater to hold my rods.
charlie
09-04-2001 16:01:35
i used pvc pipe.glued a cap on one end and put a gasket cap on the other.had them for alot of years with no problem.good luck
Tyler(WA)
09-04-2001 12:20:08
Since you're probably not going to be using the rods THAT often... I'd build a tight wooden box and use DriZit or one of the many moisture absorbing crystal products. It will save you the energy and eliminate any fire hazard.
You can always bake the rods that do absorb any moisture and dry them out quite well.
