Tool Talk Discussion Forum
Eaton 2 speed axle control
jack12345
04-09-2008 20:15:57
I have two types of axle controls one is electric the other is electric over air.I'm doing some rear axle work and can use either as they interchange.Its on a older Dodge dump with air brakes and 2 speed rear.Anyone know which control is better? Thanks, Jack
Bruce Hopf
04-10-2008 22:23:39
 Re: Eaton 2 speed axle control in reply to jack12345, 04-09-2008 20:15:57
I'd go with electric. If a wire broke while on the road, you can splice, and tape it temporarily. If an air line breaks, you will need couplers to splice it together. Who carries air line parts with them while on the road. I never did when I was driving transports. I always had a few rolls of electrical tape in the tool box.
Bruce.
dieselpaul
04-10-2008 08:53:25
my vote is for electric shift also. even if air shift motor is a lot simpler. i've broken units trying to get them apart to replace diaphram. aluminum gets rotton inside from moisture. besides that, some air systems use electric solinoid valves to direct air--more to deal with. paul
guido
04-10-2008 06:23:41
Hello jack12345.
Go with the electric system. It is easier to service and in cold weather is definately better.
The air system works fine only if the air supply is clean and dry.
Guido.
rockyhawaii
04-09-2008 22:52:44
I've seen both types quickly destroyed by bad (untrained) drivers. Unless you're the only person that is going to drive the truck, I'd go with whichever is easier for you to repair. As I remember. the mechanics where I worked seemed to get the all-electrics back on the road quicker.
