Tool Talk Discussion Forum
Craftsman Air Compressor
Lanse
04-08-2008 13:16:26
I decided to open up the drain on my compressor to let whatever water and condensation out, and the thing wouldnt let anything out. I relaesed all the air, and reached under there and turned the screw one way, nothing, then all the way the other way, still nothing. Wile i was doing this, there was about 10-20 psi in there still (i opened the valve) but no air coming out. I came up when all the air was out, and turned it on, it gained pressure. I let the pressure out, then turned the screw all the way the other way, then it still gained pressure. What giveS???
Jim B. in OH
04-11-2008 18:39:36
 Re: Craftsman Air Compressor in reply to Lanse, 04-08-2008 13:16:26
Link
mine was 1/4" pipe thread if I remember correctly. Jim B.
Gary from Muleshoe
04-09-2008 17:56:02
Didn't you just buy this compressor new a few months back?
If so return it and have them fix it or replace it. You paid good money for it, they need to stand behind it.
greygoat
04-09-2008 07:30:14
Water in the tank can freeze, if it's cold out-
side, and ice can block the drain.
Ken 46
04-09-2008 06:28:46
I am with Bob Pa. -My valve on the sears air compressor was plugged up. Finally drilled it out- and replaced. Now I drain every time I use it. I knew it was supposed to be drained - but did not take the time to do it!!!
cj3b_jeep
04-09-2008 06:14:04
jam an awl in there and it'll break stuff loose
Don c
04-09-2008 01:53:30
I drain mine every evening when I am all done, also when I first start it up I leave the drain open for a 1/2 minute or so and see how much more I get out. I also let the air regulator leak a tad, would be surprised at the amount of water you get when it runs a lot.
BobPa.
04-08-2008 20:22:57
Lanse, Once my friend wanted to do some painting on his tractors. I said we better drain the compressor tank to remove any water. To make a long story short, I took the valve clear out and still no air came out. I poked a screw driver in there and all at once it blew the screw driver out of my hand and what seemed like 5 gal of stinky water blew all over me. I don't think he must have ever drained it before and valve hole must have been full of rust. I learned my lesson that day.
Gary from Muleshoe
04-08-2008 18:01:29
Lanse I believe I would do as Jeremy suggested, then you troubles are over for good. I did this to all of mine at home and work and it makes it easier to drain if you use it a lot.
JeremyR
04-08-2008 17:11:13
I went through 3 valves before I figured out that they where crap. Mine done the oppisite and leaked air. I installed a 90, 6" of pipe, and a 1/4 turn ball valve and not had a bit of trouble scince.
Jeremy
you just need......
04-08-2008 16:56:09
to be smarter than the air compressor.
JT
04-08-2008 19:07:58
 Re: Craftsman Air Compressor in reply to you just need......, 04-08-2008 16:56:09
You do not need to make these stupid comments, he is a young man, trying to learn, at least he has enough common sense to ask before he breaks something and he needs to be commended, not ridiculed.
Jim
Lanse
04-11-2008 17:54:08
 Re: Craftsman Air Compressor in reply to JT, 04-08-2008 19:07:58
thanks Jim :-)
Lanse
04-08-2008 17:46:35
mabey you need to be less of a smart @$$
Jim K
04-08-2008 16:14:01
If you have an old copper and brass automotive radiater the drain petcocks are the same as what you have on your compressor. I've replaced mine three times. A good hardware store or Home De pot should have replacements.
And remember to drain the tank after every use.
IH2444
04-08-2008 13:55:10
yeah I had to replace the drain valve on my noisy Craftsman AC.
on mine the little cheap handle stripped out and would not open the valve.
Lanse
04-08-2008 14:03:43
 Re: Craftsman Air Compressor in reply to IH2444, 04-08-2008 13:55:10
well, its more of a screw....
lucas boy
04-08-2008 13:29:17
id try cleaning the drain cock with a stiff wire ,you may have to remove it to clean it if its still clogged.when its right, you just barly crack it so the water can drip out,open it all the way at once and it blows the water up inside the tank,, just like on truck airbrake tanks. lucas
