Tool Talk Discussion Forum
Electrical question: Coax Connectors
Kent in KC
04-06-2008 19:35:08
I have RG6 quad shielded run through my house. I've tried two different types of connectors and crimping tools but still have marginal luck getting a strong, tight connection. How do the pros do it?
Thanks.
Mort Adella
04-07-2008 06:56:30
 Re: Electrical question: Coax Connectors in reply to Kent in KC, 04-06-2008 19:35:08
third party image
I started using this type.
The special tool pushes the plastic sleve into the connector making a very strong connection.
Connectors and the tool were available at Home Improvement stores
Kent in KC
04-07-2008 05:57:13
Thanks guys! I'm headed to the electronics supply store to see if they can fix me up with some of this stuff. I appreciate it.
Kent
MikeU
04-07-2008 05:33:41
Kent, been in the catv industry for 16 years. The connectors the industry uses, as a whole, are a compression type fitting. The ones we use at the office are Gilbert Ultra-Range. (GF-UR-6)
They work on dual Rg-6, tri-shield Rg-6 and quad shield Rg-6. You will need the right prep tool.
Cable-prep makes a variety of strippers to accomplish this. ( CPT-659 ) is the one we use. The "crimper" or compression tool is also from cable prep ( CAT ). Good Luck
jack-iowa
04-07-2008 05:33:12
they have a twist type connector that work really well. most places have them.they have knurls on the end so you can get a grip on them to twist. so much better connections.
soundguy
04-07-2008 05:21:17
I agree with Tim. i use a multi stage crimper similar to what he is using.
Good ( proper ) tools cost more.. but work better for some applications.
soundguy
TimMiller
04-06-2008 20:38:48
I use ratchet crimpers. They work very well. I had the same problem you are until switching over. I bought mine at an electronics store. I use paladin 1300 series crimpers. I also have the die set to crimp insulated butt terminals which works better than any other hand crimper. Link
