Tool Talk Discussion Forum
Heating Comppressor Crankcase
Glenn F.
04-06-2008 07:29:50
My air compressors are in the unheated "haymow" of my shop. I want to rig up a crankcase heater on each of them to keep the oil warm/thin in the below zero winter weather. I suppose each of them holds about 1.5 quarts of oil. I have thought of those little magnetic electric heaters, heat tape, etc.
Do any of you have a heater set up? I don't like the idea of using lighter oil.
Thank you,
Glenn F.
greygoat
04-07-2008 09:29:48
 Re: Heating Comppressor Crankcase in reply to Glenn F., 04-06-2008 07:29:50
My compressor has an oil pump, and full pressure
lubrication, and an oil pressure gauge. It's in
an unheated garage/shop. I put Mobil synthetic
automobile engine oil in the crankcase, 5W-20,
it starts at 30 below zero, has full pressure in
a second or two, and has been running fine for
5 years.
jose bagge
04-06-2008 16:24:32
All of my shops have the compressors in "dwg houses" outside, for both space and noise- we run synthetiic oil and have never had any issues.
gold-leaf-deere
04-06-2008 15:39:08
My 5 HP compressor is in a unheated space above my shop, In cold weather I drain the air out of the tank and the compressor will start up fine, it will warm it's own oil, if I don't do this the 220AC breaker will trip every time.
Lee in Iowa
04-06-2008 15:32:10
I just put a heatlamp on mine a couple hours before I want to run it that makes it start up a lot easier. Hopefully next winter I will get around to putting synthetic in it. Lee
Kentb of SWMO
04-06-2008 15:19:12
Chambell-Hasfields second choice oil for their air compresser is Mobile 1 10W-30. Their first chioce is 100 DIN compressor oil. I have switch my compressors to Mobile 1. Heat sounds ok to if you use something built for that service. I amin SW MO so it does not get real cold here most of the time.
Kent
Jon Hagen
04-07-2008 07:38:29
 Re: Heating Comppressor Crankcase in reply to Kentb of SWMO, 04-06-2008 15:19:12
My compressor lives in an unheated shop in an area where winter temps can hit lower than - 30.
No problem starting the compressor since I filled it with Mobil 1 5W-30, and later when it became avalible, 0W-30.
Been using the synthetic motor oil in it for almost 30 years and never had a problem. I change it once per year.
I would not consider using an electric heater because of cost and fire danger. Sytnthetic oil in the compressor will make easy cold starts and less wear in the compressor.
buickanddeere
04-06-2008 11:13:43
As previously stated. Make things simple, cheap, safe and foolproof. Just us synthetic oil. An electric heater around oil is a fire looking for a place to happen.
Bob
04-06-2008 10:35:18
Go to www.grainger.com.
Enter "compressor crankcase heater" in the search box.
fixerupper
04-06-2008 10:23:48
A heater of some sort is a good idea and something I've never thought of much.(duh)
My compressor (5 HP 17 CFM) sits in a unheated storage building beside the shop. It always starts and runs OK, but heating the crankcase is not a bad idea. It can be below zero in there in the winter and over a hundred in the summer. Changing to a lighter oil for winter means I will forget to change it again in the spring and it will run in the summer with light oil. Jim
Heater..John,PA
04-06-2008 10:04:30
I use a refrigeration crankcase heater on mine. It is a 220v. heater that puts off only 20 watts of heat. I have the heater wired on the line side of the compressor switch. Therefore the heater is always on when the power is on to the compressor. Otherwise, I can keep the heater pluged in by itself so it is on all the time.
It is knows as a belly-band heater. Might try a refrigeration supply store to get one.
Believe it or not, I also have a 110volt heater around the oil pan of my service van. In the winter-time I keep the "van" plugged in to 110 v.
Hope this helps.
s.crum
04-06-2008 09:40:29
I had a similar issue with a Quincy QR-25 for my plasma rig. This is a forced lubrication. I went with the factory recommended paraffin based 5W turbine oil for sub-zero during the winter and 20W for warm weather. No problens yet.
leroy in ne
04-06-2008 09:33:25
had trouble with 3 horse compressor blowing fuses when temp was below about 15 degrees. at anothers suggestion i switched to amzoil 20w50 synthetic compressor oil. no problems at temps of 10 below. expensive thou like $6.00 a qt. leroy
